WARN SonosFaultInterceptor - Error: org.apache.cxf.intercept
Postby Mr.Bump » Tue Sep 20, 2022 3:38 pm
I've encountered an issue that doesn't seem to have been reported on the forum.
Problem Description: I'm seeing a lot of errors in my logs when accessing subsonic from the Sonos S2 app. It is also very sluggish in loading the library. Any ideas of a fix for this?
Troubleshooting Steps: Tried memory increase
Playback Application and version: Sonos S2 (14.16, Build 69133120) on Android 12
Subsonic Version: 6.1.6 (build 0cfa60) – November 10, 2019
Server Version: jetty-6.1.x, java 1.8.0_201, HSQLDB, Linux (246.2 MB / 537.0 MB)
Hardware Platform: Linux (ubuntu 20.04)
Java Memory Limit: 4096Mb
Problem Filename: N/A
Output from ffmpeg -i:
ffmpeg version 4.2.7-0ubuntu0.1 Copyright (c) 2000-2022 the FFmpeg developers
  built with gcc 9 (Ubuntu 9.4.0-1ubuntu1~20.04.1)
  configuration: --prefix=/usr --extra-version=0ubuntu0.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-nvenc --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
  libavutil      56. 31.100 / 56. 31.100
  libavcodec     58. 54.100 / 58. 54.100
  libavformat    58. 29.100 / 58. 29.100
  libavdevice    58.  8.100 / 58.  8.100
  libavfilter     7. 57.100 /  7. 57.100
  libavresample   4.  0.  0 /  4.  0.  0
  libswscale      5.  5.100 /  5.  5.100
  libswresample   3.  5.100 /  3.  5.100
  libpostproc    55.  5.100 / 55.  5.100
Missing argument for option 'i'.
Error splitting the argument list: Invalid argument
Last ten log file lines including stacktrace:
[2022-09-20 03:00:42,675] INFO MediaScannerService - Scanned media library with 31129 entries.
[2022-09-20 03:00:42,675] INFO MediaScannerService - Marking non-present files.
[2022-09-20 03:00:43,401] INFO MediaScannerService - Marking non-present artists.
[2022-09-20 03:00:43,405] INFO MediaScannerService - Marking non-present albums.
[2022-09-20 03:00:43,442] INFO MediaScannerService - Completed media library scan.
[2022-09-20 03:00:46,650] INFO PlaylistService - Starting playlist import.
[2022-09-20 03:00:46,650] INFO PlaylistService - Completed playlist import.
[2022-09-20 15:41:48,926] INFO PodcastService - Starting scheduled Podcast refresh.
[2022-09-20 15:41:48,926] INFO PodcastService - Completed scheduled Podcast refresh.
[2022-09-20 15:54:53,149] INFO PlayerDao - Created player 8.
[2022-09-20 15:54:53,381] INFO VersionService - Resolved latest Subsonic final version to: 6.1.6
[2022-09-20 15:54:53,381] INFO VersionService - Resolved latest Subsonic beta version to: 6.1.beta2
[2022-09-20 15:55:05,563] WARN SonosFaultInterceptor - Error: org.apache.cxf.interceptor.Fault: For input string: "library"
        at org.apache.cxf.service.invoker.AbstractInvoker.createFault(AbstractInvoker.java:155)
        at org.apache.cxf.jaxws.AbstractJAXWSMethodInvoker.createFault(AbstractJAXWSMethodInvoker.java:86)
        at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:121)
        at org.apache.cxf.jaxws.JAXWSMethodInvoker.invoke(JAXWSMethodInvoker.java:61)
        at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:75)
        at org.apache.cxf.interceptor.ServiceInvokerInterceptor$1.run(ServiceInvokerInterceptor.java:58)
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
        at java.util.concurrent.FutureTask.run(FutureTask.java:266)
        at org.apache.cxf.workqueue.SynchronousExecutor.execute(SynchronousExecutor.java:37)
        at org.apache.cxf.interceptor.ServiceInvokerInterceptor.handleMessage(ServiceInvokerInterceptor.java:106)
        at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:263)
        at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121)
        at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:206)
        at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:218)
        at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:200)
        at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:114)
        at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:184)
        at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doPost(AbstractHTTPServlet.java:107)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
        at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:163)
        at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:135)
        at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:844)
        at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:644)
Caused by: java.lang.NumberFormatException: For input string: "library"
        at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65)
        at java.lang.Integer.parseInt(Integer.java:580)
        at java.lang.Integer.parseInt(Integer.java:615)
        at net.sourceforge.subsonic.service.SonosService.getExtendedMetadata(SonosService.java:296)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.lang.reflect.Method.invoke(Method.java:498)
        at org.apache.cxf.service.invoker.AbstractInvoker.performInvocation(AbstractInvoker.java:173)
        at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:89)
        ... 62 more
Mr.Bump
