Need help building from source
Postby carlo_alb » Fri Jan 06, 2023 9:19 pm
Hi everyone, I am trying to compile with Maven but I am getting this error:
mvn compile
[INFO] Scanning for projects...
[ERROR] [ERROR] Some problems were encountered while processing the POMs:
[FATAL] Non-resolvable parent POM for net.sourceforge.subsonic:subsonic-main:5.0: net.sourceforge.subsonic:subsonic:pom:5.0 was not found in http://nexus.ailis.de/content/groups/public/ during a previous attempt. This failure was cached in the local repository and resolution is not reattempted until the update interval of ailis has elapsed or updates are forced and 'parent.relativePath' points at wrong local POM @ line 6, column 10
[ERROR] The build could not read 1 project -> [Help 1]
[ERROR]
[ERROR]   The project net.sourceforge.subsonic:subsonic-main:5.0 (/home/carlo/Code/java/subsonic_crack/subsonic/subsonic-main/pom.xml) has 1 error
[ERROR]     Non-resolvable parent POM for net.sourceforge.subsonic:subsonic-main:5.0: net.sourceforge.subsonic:subsonic:pom:5.0 was not found in http://nexus.ailis.de/content/groups/public/ during a previous attempt. This failure was cached in the local repository and resolution is not reattempted until the update interval of ailis has elapsed or updates are forced and 'parent.relativePath' points at wrong local POM @ line 6, column 10 -> [Help 2]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/ProjectBuildingException
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/UnresolvableModelException
This is a pastebin to my subsonic-main/pom.xml https://pastebin.com/WGyuvJYd
This is the error that IntellliJ gives me:
Cannot resolve com.github.hakko.musiccabinet:musiccabinet-server:0.7.24
Does anyone know how to fix this? Thanks
carlo_alb
Users browsing this forum: No registered users and 82 guests
