failed to create port?
Postby pattirules » Sun Oct 27, 2024 3:10 pm
was working for years...suddenly getting this
anyone know what i need to do?
[2024-10-27 09:36:28,649] INFO NetworkService - Successfully forwarding port 4040.
[2024-10-27 10:36:28,672] WARN NetworkService - Failed to create port forwarding.
java.lang.Exception: null: Error: Current state of service prevents invoking that action. Connection error or no response received.
at net.sourceforge.subsonic.service.upnp.ClingRouter.addPortMappingImpl(ClingRouter.java:98)
at net.sourceforge.subsonic.service.upnp.ClingRouter.addPortMapping(ClingRouter.java:71)
at net.sourceforge.subsonic.service.NetworkService$PortForwardingTask.execute(NetworkService.java:130)
at net.sourceforge.subsonic.service.NetworkService$Task.run(NetworkService.java:291)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
pattirules
Re: failed to create port?
Postby pattirules » Sun Oct 27, 2024 3:12 pm
now this
java.lang.IllegalStateException: The userCache Cache is not alive (STATUS_SHUTDOWN)
at net.sf.ehcache.Cache$CacheStatus.checkAlive(Cache.java:4259)
at net.sf.ehcache.Cache.checkStatus(Cache.java:2722)
at net.sf.ehcache.Cache.get(Cache.java:1616)
at net.sf.ehcache.Cache.get(Cache.java:1597)
at org.acegisecurity.providers.dao.cache.EhCacheBasedUserCache.getUserFromCache(EhCacheBasedUserCache.java:66)
at org.acegisecurity.providers.dao.AbstractUserDetailsAuthenticationProvider.authenticate(AbstractUserDetailsAuthenticationProvider.java:113)
at org.acegisecurity.providers.ProviderManager.doAuthentication(ProviderManager.java:195)
at org.acegisecurity.AbstractAuthenticationManager.authenticate(AbstractAuthenticationManager.java:45)
at org.acegisecurity.intercept.AbstractSecurityInterceptor.beforeInvocation(AbstractSecurityInterceptor.java:298)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:104)
at net.sourceforge.subsonic.filter.ResponseHeaderFilter.doFilter(ResponseHeaderFilter.java:29)
pattirules
Postby pattirules » Sun Oct 27, 2024 3:22 pm
fixed second problem but what would cause port forwarding to randomly not forward all the time
pattirules
Postby bushman4 » Mon Oct 28, 2024 3:36 pm
Has something changed in your network? New router, new firmware on the router, etc? This appears to be a uPnP problem telling your router to forward the port.
I usually just manually forward the port on the router personally... I find it more reliable.
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby pattirules » Mon Oct 28, 2024 11:05 pm
thanks for the response the port forwarding dropped three times today i restart subsonic and it goes until it drops i havent changed anything at all i just dont get it
pattirules
