3.7 beta 1 crashes in jukebox mode
Postby geiman » Wed Jun 10, 2009 1:29 am
Not sure if anyone else has had this problem; I've been searching for a few days with no luck. In 3.7 beta 1, subsonic crashes for seemingly no reason; I just noticed that a song I have that is only 128 kbps does not crash subsonic, however songs that are 192 kbps cause subsonic to crash. If I simply stream the music to my browsers flash player, it works great, but the jukebox feature for some reason wants to crash. I've pasted the error log that is created after the crash; it looks like the crash deals with the jvm. Not sure if that means it's a problem with my java or with subsonic. Anyone else have this problem? If its simply something with the beta thats fine, it just kills me that I can't fix the problem, or at least know what the cause is.
Here is the log:
# An unexpected error has been detected by Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0x00007fe7b13a1610, pid=4619, tid=140633112115536
# Java VM: Java HotSpot(TM) 64-Bit Server VM (11.3-b02 mixed mode linux-amd64)
# Problematic frame:
# C  0x00007fe7b13a1610
# If you would like to submit a bug report, please visit:
#   http://java.sun.com/webapps/bugreport/crash.jsp
---------------  T H R E A D  ---------------
Current thread is native thread
siginfo:si_signo=SIGSEGV: si_errno=0, si_code=1 (SEGV_MAPERR), si_addr=0x00007fe7b13a1610
Registers:
RAX=0x00007fe7b13a1610, RBX=0x0000000000000020, RCX=0x0000000000000000, RDX=0x0000000000000000
RSP=0x00007fe7b2b0f118, RBP=0x00007fe7c75932a0, RSI=0x00007fe7b2b0f950, RDI=0x00007fe7b4a5ec10
R8 =0x00007fe7b41ef5c0, R9 =0x00007fe7b2b0f950, R10=0x0000000000000008, R11=0x0000000000000246
R12=0x00007fe7b2b0fa20, R13=0x0000000000000000, R14=0x00007fe7c7593280, R15=0x0000000000000000
RIP=0x00007fe7b13a1610, EFL=0x0000000000010202, CSGSFS=0x0000000000000033, ERR=0x0000000000000014
  TRAPNO=0x000000000000000e
Top of Stack: (sp=0x00007fe7b2b0f118)
0x00007fe7b2b0f118:   00007fe7c7383459 00007fe7b2b0f950
0x00007fe7b2b0f128:   0000000000000000 0000000000000000
0x00007fe7b2b0f138:   0000000000000000 0000000000000000
0x00007fe7b2b0f148:   0000000000000000 0000000000000000
0x00007fe7b2b0f158:   0000000000000000 0000000000000000
0x00007fe7b2b0f168:   0000000000000000 0000000000000000
0x00007fe7b2b0f178:   0000000000000000 0000000000000000
0x00007fe7b2b0f188:   0000000000000000 0000000000000000
0x00007fe7b2b0f198:   0000000000000000 0000000000000000
0x00007fe7b2b0f1a8:   0000000000000000 0000000000000000
0x00007fe7b2b0f1b8:   942b50f5c87d974f 0000000000000000
0x00007fe7b2b0f1c8:   00007fe7b2b0f950 00007fe7c77b8040
0x00007fe7b2b0f1d8:   00007fe7b39de5c0 6be435942a3d974f
0x00007fe7b2b0f1e8:   6be4de85af7f974f 0000000000000000
0x00007fe7b2b0f1f8:   0000000000000000 0000000000000000
0x00007fe7b2b0f208:   0000000000000000 0000000000000000
0x00007fe7b2b0f218:   0000000000000000 0000000000000000
0x00007fe7b2b0f228:   00007fe7b2b0f950 0000000000000000
0x00007fe7b2b0f238:   0000000000000000 00007fe7b2b0f950
0x00007fe7b2b0f248:   00007fe7c77b8040 00007fe7b39de5c0
0x00007fe7b2b0f258:   00007fe7c6eebfcd 0000000000000000
0x00007fe7b2b0f268:   0000000000000000 0000000000000000
0x00007fe7b2b0f278:   0000000000000000 0000000000000000
0x00007fe7b2b0f288:   0000000000000000 0000000000000000
0x00007fe7b2b0f298:   0000000000000000 0000000000000000
0x00007fe7b2b0f2a8:   0000000000000000 0000000000000000
0x00007fe7b2b0f2b8:   0000000000000000 0000000000000000
0x00007fe7b2b0f2c8:   0000000000000000 0000000000000000
0x00007fe7b2b0f2d8:   0000000000000000 0000000000000000
0x00007fe7b2b0f2e8:   0000000000000000 0000000000000000
0x00007fe7b2b0f2f8:   0000000000000000 0000000000000000
0x00007fe7b2b0f308:   0000000000000000 0000000000000000
Instructions: (pc=0x00007fe7b13a1610)
0x00007fe7b13a1600:
[error occurred during error reporting (printing registers, top of stack, instructions near pc), id 0xb]
Stack: [0x00007fe7b2a0f000,0x00007fe7b2b10000],  sp=0x00007fe7b2b0f118,  free space=1024k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
---------------  P R O C E S S  ---------------
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
PSYoungGen      total 18048K, used 8514K [0x00007fe7c0d70000, 0x00007fe7c21e0000, 0x00007fe7c22c0000)
  eden space 15424K, 46% used [0x00007fe7c0d70000,0x00007fe7c146c160,0x00007fe7c1c80000)
  from space 2624K, 51% used [0x00007fe7c1f50000,0x00007fe7c20a4898,0x00007fe7c21e0000)
  to   space 2752K, 0% used [0x00007fe7c1c80000,0x00007fe7c1c80000,0x00007fe7c1f30000)
PSOldGen        total 25664K, used 15917K [0x00007fe7be2c0000, 0x00007fe7bfbd0000, 0x00007fe7c0d70000)
  object space 25664K, 62% used [0x00007fe7be2c0000,0x00007fe7bf24b6b8,0x00007fe7bfbd0000)
PSPermGen       total 52608K, used 37309K [0x00007fe7b8ec0000, 0x00007fe7bc220000, 0x00007fe7be2c0000)
  object space 52608K, 70% used [0x00007fe7b8ec0000,0x00007fe7bb32f418,0x00007fe7bc220000)
Dynamic libraries:
40000000-40009000 r-xp 00000000 08:01 2728516                            /usr/lib/jvm/java-6-sun-1.6.0.13/jre/bin/java
40108000-4010a000 rwxp 00008000 08:01 2728516                            /usr/lib/jvm/java-6-sun-1.6.0.13/jre/bin/java
4193b000-43405000 rwxp 4193b000 00:00 0                                  [heap]
7fe7b17de000-7fe7b18b7000 r-xp 00000000 08:01 2344569                    /usr/lib/libasound.so.2.0.0
7fe7b18b7000-7fe7b1ab7000 ---p 000d9000 08:01 2344569                    /usr/lib/libasound.so.2.0.0
7fe7b1ab7000-7fe7b1aba000 r-xp 000d9000 08:01 2344569                    /usr/lib/libasound.so.2.0.0
7fe7b1aba000-7fe7b1abe000 rwxp 000dc000 08:01 2344569                    /usr/lib/libasound.so.2.0.0
7fe7b1abe000-7fe7b1acc000 r-xp 00000000 08:01 2736144                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libjsoundalsa.so
7fe7b1acc000-7fe7b1bcb000 ---p 0000e000 08:01 2736144                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libjsoundalsa.so
7fe7b1bcb000-7fe7b1bce000 rwxp 0000d000 08:01 2736144                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libjsoundalsa.so
7fe7b1bce000-7fe7b1bfa000 r-xp 00000000 08:01 2736151                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libjsound.so
7fe7b1bfa000-7fe7b1cfa000 ---p 0002c000 08:01 2736151                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libjsound.so
7fe7b1cfa000-7fe7b1d02000 rwxp 0002c000 08:01 2736151                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libjsound.so
7fe7b1d02000-7fe7b1d04000 rwxp 7fe7b1d02000 00:00 0
7fe7b1d04000-7fe7b1d07000 rwxp 7fe7b1d04000 00:00 0
7fe7b1d07000-7fe7b1e05000 rwxp 7fe7b1d07000 00:00 0
7fe7b1e05000-7fe7b1e08000 ---p 7fe7b1e05000 00:00 0
7fe7b1e08000-7fe7b1f06000 rwxp 7fe7b1e08000 00:00 0
7fe7b1f06000-7fe7b1f09000 ---p 7fe7b1f06000 00:00 0
7fe7b1f09000-7fe7b2007000 rwxp 7fe7b1f09000 00:00 0
7fe7b2007000-7fe7b2085000 r-xp 00000000 08:01 2736143                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libfontmanager.so
7fe7b2085000-7fe7b2184000 ---p 0007e000 08:01 2736143                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libfontmanager.so
7fe7b2184000-7fe7b219a000 rwxp 0007d000 08:01 2736143                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libfontmanager.so
7fe7b219a000-7fe7b21ab000 rwxp 7fe7b219a000 00:00 0
7fe7b21ab000-7fe7b21f7000 r-xp 00000000 08:01 2736179                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libcmm.so
7fe7b21f7000-7fe7b22f7000 ---p 0004c000 08:01 2736179                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libcmm.so
7fe7b22f7000-7fe7b2304000 rwxp 0004c000 08:01 2736179                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libcmm.so
7fe7b2304000-7fe7b2305000 rwxp 7fe7b2304000 00:00 0
7fe7b2305000-7fe7b2331000 r-xp 00000000 08:01 2736170                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libjpeg.so
7fe7b2331000-7fe7b2431000 ---p 0002c000 08:01 2736170                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libjpeg.so
7fe7b2431000-7fe7b2437000 rwxp 0002c000 08:01 2736170                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libjpeg.so
7fe7b2437000-7fe7b243c000 r-xp 00000000 08:01 2736175                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/headless/libmawt.so
7fe7b243c000-7fe7b253b000 ---p 00005000 08:01 2736175                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/headless/libmawt.so
7fe7b253b000-7fe7b253d000 rwxp 00004000 08:01 2736175                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/headless/libmawt.so
7fe7b253d000-7fe7b25cf000 r-xp 00000000 08:01 2736178                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libawt.so
7fe7b25cf000-7fe7b26ce000 ---p 00092000 08:01 2736178                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libawt.so
7fe7b26ce000-7fe7b26e7000 rwxp 00091000 08:01 2736178                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libawt.so
7fe7b26e7000-7fe7b270c000 rwxp 7fe7b26e7000 00:00 0
7fe7b270c000-7fe7b270f000 ---p 7fe7b270c000 00:00 0
7fe7b270f000-7fe7b280d000 rwxp 7fe7b270f000 00:00 0
7fe7b280d000-7fe7b2810000 ---p 7fe7b280d000 00:00 0
7fe7b2810000-7fe7b290e000 rwxp 7fe7b2810000 00:00 0
7fe7b290e000-7fe7b2911000 ---p 7fe7b290e000 00:00 0
7fe7b2911000-7fe7b2a0f000 rwxp 7fe7b2911000 00:00 0
7fe7b2a0f000-7fe7b2a12000 rwxp 7fe7b2a0f000 00:00 0
7fe7b2a12000-7fe7b2b10000 rwxp 7fe7b2a12000 00:00 0
7fe7b2b10000-7fe7b2b13000 ---p 7fe7b2b10000 00:00 0
7fe7b2b13000-7fe7b2c11000 rwxp 7fe7b2b13000 00:00 0
7fe7b2c11000-7fe7b2c14000 ---p 7fe7b2c11000 00:00 0
7fe7b2c14000-7fe7b2d12000 rwxp 7fe7b2c14000 00:00 0
7fe7b2d12000-7fe7b2d15000 ---p 7fe7b2d12000 00:00 0
7fe7b2d15000-7fe7b2e13000 rwxp 7fe7b2d15000 00:00 0
7fe7b2e13000-7fe7b2e16000 ---p 7fe7b2e13000 00:00 0
7fe7b2e16000-7fe7b2f14000 rwxp 7fe7b2e16000 00:00 0
7fe7b2f14000-7fe7b2f17000 ---p 7fe7b2f14000 00:00 0
7fe7b2f17000-7fe7b3015000 rwxp 7fe7b2f17000 00:00 0
7fe7b3015000-7fe7b3018000 ---p 7fe7b3015000 00:00 0
7fe7b3018000-7fe7b3116000 rwxp 7fe7b3018000 00:00 0
7fe7b3116000-7fe7b3119000 ---p 7fe7b3116000 00:00 0
7fe7b3119000-7fe7b3217000 rwxp 7fe7b3119000 00:00 0
7fe7b3217000-7fe7b321a000 ---p 7fe7b3217000 00:00 0
7fe7b321a000-7fe7b3318000 rwxp 7fe7b321a000 00:00 0
7fe7b3318000-7fe7b3418000 rwxs 00000000 08:01 5964898                    /var/subsonic/db/subsonic.data
7fe7b3418000-7fe7b341b000 ---p 7fe7b3418000 00:00 0
7fe7b341b000-7fe7b3519000 rwxp 7fe7b341b000 00:00 0
7fe7b3519000-7fe7b3520000 r-xp 00000000 08:01 2736136                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libnio.so
7fe7b3520000-7fe7b361f000 ---p 00007000 08:01 2736136                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libnio.so
7fe7b361f000-7fe7b3621000 rwxp 00006000 08:01 2736136                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libnio.so
7fe7b3621000-7fe7b3624000 ---p 7fe7b3621000 00:00 0
7fe7b3624000-7fe7b3722000 rwxp 7fe7b3624000 00:00 0
7fe7b376a000-7fe7b376b000 r-xs 00000000 08:01 5964440                    /var/subsonic/jetty/webapp/style/shadow.png
7fe7b376b000-7fe7b376c000 r-xs 00000000 08:01 5964434                    /var/subsonic/jetty/webapp/style/lowerleftfade.png
7fe7b376c000-7fe7b376d000 r-xs 00000000 08:01 5964441                    /var/subsonic/jetty/webapp/style/upperrightfade.png
7fe7b376d000-7fe7b3776000 r-xs 00000000 08:01 5873727                    /var/cache/fontconfig/945677eb7aeaf62f1d50efc3fb3ec7d8-x86-64.cache-2
7fe7b3776000-7fe7b3779000 r-xs 00000000 08:01 5873736                    /var/cache/fontconfig/e383d7ea5fbe662a33d9b44caf393297-x86-64.cache-2
7fe7b3779000-7fe7b377a000 r-xs 00000000 08:01 5873722                    /var/cache/fontconfig/4c73fe0c47614734b17d736dbde7580a-x86-64.cache-2
7fe7b377a000-7fe7b377e000 r-xs 00000000 08:01 5873728                    /var/cache/fontconfig/a755afe4a08bf5b97852ceb7400b47bc-x86-64.cache-2
7fe7b377e000-7fe7b3782000 r-xs 00000000 08:01 5873724                    /var/cache/fontconfig/6d41288fd70b0be22e8c3a91e032eec0-x86-64.cache-2
7fe7b3782000-7fe7b3785000 r-xs 00000000 08:01 5873734                    /var/cache/fontconfig/de156ccd2eddbdc19d37a45b8b2aac9c-x86-64.cache-2
7fe7b3785000-7fe7b3790000 r-xs 00000000 08:01 5873737                    /var/cache/fontconfig/e3de0de479f42330eadf588a55fb5bf4-x86-64.cache-2
7fe7b3790000-7fe7b379f000 r-xs 00000000 08:01 5873717                    /var/cache/fontconfig/0f34bcd4b6ee430af32735b75db7f02b-x86-64.cache-2
7fe7b379f000-7fe7b37a2000 r-xs 00000000 08:01 5873733                    /var/cache/fontconfig/ddd4086aec35a5275babba44bb759c3c-x86-64.cache-2
7fe7b37a2000-7fe7b37a3000 r-xs 00000000 08:01 5873720                    /var/cache/fontconfig/4794a0821666d79190d59a36cb4f44b5-x86-64.cache-2
7fe7b37a3000-7fe7b37ac000 r-xs 00000000 08:01 5873731                    /var/cache/fontconfig/d52a8644073d54c13679302ca1180695-x86-64.cache-2
7fe7b37ac000-7fe7b37b3000 r-xs 00000000 08:01 5873716                    /var/cache/fontconfig/089dead882dea3570ffc31a9898cfb69-x86-64.cache-2
7fe7b37b3000-7fe7b37bd000 r-xs 00000000 08:01 5874050                    /var/cache/fontconfig/e13b20fdb08344e0e664864cc2ede53d-x86-64.cache-2
7fe7b37bd000-7fe7b37c0000 r-xs 00000000 08:01 5873726                    /var/cache/fontconfig/7ef2298fde41cc6eeb7af42e48b7d293-x86-64.cache-2
7fe7b37c0000-7fe7b37c1000 r-xs 00000000 08:01 5964269                    /var/subsonic/jetty/webapp/icons/midnight/forward.png
7fe7b37c1000-7fe7b37c2000 r-xs 00000000 08:01 5964266                    /var/subsonic/jetty/webapp/icons/home.png
7fe7b37c2000-7fe7b37cc000 r-xs 00000000 08:01 5964370                    /var/subsonic/jetty/webapp/script/effects.js
7fe7b37cc000-7fe7b37ec000 r-xs 00000000 08:01 5964399                    /var/subsonic/jetty/webapp/script/prototype.js
7fe7b37ec000-7fe7b37ef000 r-xs 000cb000 08:01 2728439                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/ext/localedata.jar
7fe7b37ef000-7fe7b37f6000 r-xs 00110000 08:01 2728630                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/resources.jar
7fe7b37f6000-7fe7b3803000 r-xs 000fa000 08:01 5964865                    /var/subsonic/jetty/webapp/WEB-INF/lib/jfreechart-1.0.0.jar
7fe7b3803000-7fe7b3809000 r-xs 0002e000 08:01 5964871                    /var/subsonic/jetty/webapp/WEB-INF/lib/radeox-1.0-b2.jar
7fe7b3809000-7fe7b3812000 r-xs 00058000 08:01 5964880                    /var/subsonic/jetty/webapp/WEB-INF/lib/standard-1.1.2.jar
7fe7b3812000-7fe7b3818000 r-xs 0003f000 08:01 5964849                    /var/subsonic/jetty/webapp/WEB-INF/lib/cglib-2.1_3.jar
7fe7b3818000-7fe7b381e000 r-xs 00031000 08:01 5964878                    /var/subsonic/jetty/webapp/WEB-INF/lib/spring-web-2.5.jar
7fe7b381e000-7fe7b3822000 r-xs 0002f000 08:01 5964856                    /var/subsonic/jetty/webapp/WEB-INF/lib/commons-lang-2.1.jar
7fe7b3822000-7fe7b3829000 r-xs 00071000 08:01 5964882                    /var/subsonic/jetty/webapp/WEB-INF/lib/subsonic-amazon-2006-03-08.jar
7fe7b3829000-7fe7b383d000 r-xs 00174000 08:01 5964847                    /var/subsonic/jetty/webapp/WEB-INF/lib/axis-1.2.1.jar
7fe7b383d000-7fe7b383f000 r-xs 00004000 08:01 5964867                    /var/subsonic/jetty/webapp/WEB-INF/lib/jstl-1.1.2.jar
7fe7b383f000-7fe7b3840000 r-xs 00005000 08:01 5964869                    /var/subsonic/jetty/webapp/WEB-INF/lib/mp3spi-1.9.4.jar
7fe7b3840000-7fe7b3842000 r-xs 0000a000 08:01 5964881                    /var/subsonic/jetty/webapp/WEB-INF/lib/string-1.1.0.jar
7fe7b3842000-7fe7b3844000 r-xs 0000b000 08:01 5964853                    /var/subsonic/jetty/webapp/WEB-INF/lib/commons-fileupload-1.2.jar
7fe7b3844000-7fe7b3849000 r-xs 00034000 08:01 5964859                    /var/subsonic/jetty/webapp/WEB-INF/lib/ehcache-1.6.0-beta3.jar
7fe7b3849000-7fe7b384b000 r-xs 00006000 08:01 5964862                    /var/subsonic/jetty/webapp/WEB-INF/lib/jaxrpc-1.1.jar
7fe7b384b000-7fe7b3852000 r-xs 0004a000 08:01 5964879                    /var/subsonic/jetty/webapp/WEB-INF/lib/spring-webmvc-2.5.jar
7fe7b3852000-7fe7b3855000 r-xs 00012000 08:01 5964855                    /var/subsonic/jetty/webapp/WEB-INF/lib/commons-io-1.3.1.jar
7fe7b3855000-7fe7b385b000 r-xs 00030000 08:01 5964877                    /var/subsonic/jetty/webapp/WEB-INF/lib/spring-tx-2.5.jar
7fe7b385b000-7fe7b385e000 r-xs 0000f000 08:01 5964852                    /var/subsonic/jetty/webapp/WEB-INF/lib/commons-discovery-0.2.jar
7fe7b385e000-7fe7b386b000 r-xs 0007c000 08:01 5964851                    /var/subsonic/jetty/webapp/WEB-INF/lib/commons-collections-3.1.jar
7fe7b386b000-7fe7b386e000 r-xs 0000d000 08:01 5964883                    /var/subsonic/jetty/webapp/WEB-INF/lib/subsonic-jme-player-3.7.beta1.jar
7fe7b386e000-7fe7b3871000 r-xs 00017000 08:01 5964866                    /var/subsonic/jetty/webapp/WEB-INF/lib/jlayer-1.0.1.jar
7fe7b3871000-7fe7b387e000 r-xs 00079000 08:01 5964843                    /var/subsonic/jetty/webapp/WEB-INF/lib/acegi-security-1.0.5.jar
7fe7b387e000-7fe7b3885000 r-xs 00044000 08:01 5964876                    /var/subsonic/jetty/webapp/WEB-INF/lib/spring-jdbc-2.5.jar
7fe7b3885000-7fe7b3888000 r-xs 00023000 08:01 5964864                    /var/subsonic/jetty/webapp/WEB-INF/lib/jdom-1.0.jar
7fe7b3888000-7fe7b3889000 r-xs 00002000 08:01 5964848                    /var/subsonic/jetty/webapp/WEB-INF/lib/basicplayer-3.0.jar
7fe7b3889000-7fe7b3893000 r-xs 00071000 08:01 5964858                    /var/subsonic/jetty/webapp/WEB-INF/lib/dwr-2.0.3.jar
7fe7b3893000-7fe7b389e000 r-xs 00061000 08:01 5964873                    /var/subsonic/jetty/webapp/WEB-INF/lib/spring-context-2.5.jar
7fe7b389e000-7fe7b38a0000 r-xs 0000e000 08:01 5964870                    /var/subsonic/jetty/webapp/WEB-INF/lib/oro-2.0.8.jar
7fe7b38a0000-7fe7b38a3000 r-xs 0001e000 08:01 5964884                    /var/subsonic/jetty/webapp/WEB-INF/lib/tritonus_share-0.3.6.jar
7fe7b38a3000-7fe7b38aa000 r-xs 0003c000 08:01 5964875                    /var/subsonic/jetty/webapp/WEB-INF/lib/spring-core-2.5.jar
7fe7b38aa000-7fe7b38b4000 r-xs 00067000 08:01 5964872                    /var/subsonic/jetty/webapp/WEB-INF/lib/spring-beans-2.5.jar
7fe7b38b4000-7fe7b38b7000 r-xs 00014000 08:01 5964874                    /var/subsonic/jetty/webapp/WEB-INF/lib/spring-context-support-2.5.jar
7fe7b38b7000-7fe7b38b8000 r-xs 00006000 08:01 5964846                    /var/subsonic/jetty/webapp/WEB-INF/lib/asm-1.5.3.jar
7fe7b38b8000-7fe7b38bd000 r-xs 00021000 08:01 5964860                    /var/subsonic/jetty/webapp/WEB-INF/lib/entagged-audioformats-0.15.jar
7fe7b38bd000-7fe7b38c0000 r-xs 0001c000 08:01 5964885                    /var/subsonic/jetty/webapp/WEB-INF/lib/wsdl4j-1.5.1.jar
7fe7b38c0000-7fe7b38cf000 r-xs 000e6000 08:01 5964844                    /var/subsonic/jetty/webapp/WEB-INF/lib/ant-zip-1.6.2.jar
7fe7b38cf000-7fe7b38d7000 r-xs 0004f000 08:01 5964868                    /var/subsonic/jetty/webapp/WEB-INF/lib/log4j-1.2.9.jar
7fe7b38d7000-7fe7b38df000 r-xs 00096000 08:01 5964861                    /var/subsonic/jetty/webapp/WEB-INF/lib/hsqldb-1.8.0.7.jar
7fe7b38df000-7fe7b38e2000 ---p 7fe7b38df000 00:00 0
7fe7b38e2000-7fe7b39e0000 rwxp 7fe7b38e2000 00:00 0
7fe7b39e0000-7fe7b39f4000 r-xp 00000000 08:01 16507001                   /lib/libresolv-2.9.so
7fe7b39f4000-7fe7b3bf4000 ---p 00014000 08:01 16507001                   /lib/libresolv-2.9.so
7fe7b3bf4000-7fe7b3bf5000 r-xp 00014000 08:01 16507001                   /lib/libresolv-2.9.so
7fe7b3bf5000-7fe7b3bf6000 rwxp 00015000 08:01 16507001                   /lib/libresolv-2.9.so
7fe7b3bf6000-7fe7b3bf8000 rwxp 7fe7b3bf6000 00:00 0
7fe7b3bf8000-7fe7b3bfd000 r-xp 00000000 08:01 16506963                   /lib/libnss_dns-2.9.so
7fe7b3bfd000-7fe7b3dfc000 ---p 00005000 08:01 16506963                   /lib/libnss_dns-2.9.so
7fe7b3dfc000-7fe7b3dfd000 r-xp 00004000 08:01 16506963                   /lib/libnss_dns-2.9.so
7fe7b3dfd000-7fe7b3dfe000 rwxp 00005000 08:01 16506963                   /lib/libnss_dns-2.9.so
7fe7b3dfe000-7fe7b3e00000 r-xp 00000000 08:01 16506971                   /lib/libnss_mdns4_minimal.so.2
7fe7b3e00000-7fe7b3fff000 ---p 00002000 08:01 16506971                   /lib/libnss_mdns4_minimal.so.2
7fe7b3fff000-7fe7b4000000 rwxp 00001000 08:01 16506971                   /lib/libnss_mdns4_minimal.so.2
7fe7b4000000-7fe7b6a2f000 rwxp 7fe7b4000000 00:00 0
7fe7b6a2f000-7fe7b8000000 ---p 7fe7b6a2f000 00:00 0
7fe7b8000000-7fe7b8001000 r-xs 0000c000 08:01 5964857                    /var/subsonic/jetty/webapp/WEB-INF/lib/commons-logging-1.1.jar
7fe7b8001000-7fe7b8007000 r-xs 00043000 08:01 5964863                    /var/subsonic/jetty/webapp/WEB-INF/lib/jcommon-1.0.0.jar
7fe7b8007000-7fe7b8018000 r-xs 00dd0000 08:01 5914679                    /var/subsonic/standalone/subsonic.war
7fe7b8018000-7fe7b802b000 r-xp 00000000 08:01 2736135                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libnet.so
7fe7b802b000-7fe7b812c000 ---p 00013000 08:01 2736135                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libnet.so
7fe7b812c000-7fe7b812f000 rwxp 00014000 08:01 2736135                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libnet.so
7fe7b812f000-7fe7b81b6000 r-xs 00850000 08:01 5914683                    /var/subsonic/standalone/subsonic-booter-jar-with-dependencies.jar
7fe7b8208000-7fe7b8209000 rwxp 7fe7b8208000 00:00 0
7fe7b8209000-7fe7b820a000 r-xs 00000000 08:01 5964377                    /var/subsonic/jetty/webapp/script/fancyzoom/images/zoom-caption-r.png
7fe7b820a000-7fe7b820b000 r-xs 00000000 08:01 5964375                    /var/subsonic/jetty/webapp/script/fancyzoom/images/zoom-caption-fill.png
7fe7b820b000-7fe7b820c000 r-xs 00000000 08:01 5964376                    /var/subsonic/jetty/webapp/script/fancyzoom/images/zoom-caption-l.png
7fe7b820c000-7fe7b820d000 r-xs 00000000 08:01 5964385                    /var/subsonic/jetty/webapp/script/fancyzoom/images/zoom-shadow8.png
7fe7b820d000-7fe7b820e000 r-xs 00000000 08:01 5964384                    /var/subsonic/jetty/webapp/script/fancyzoom/images/zoom-shadow7.png
7fe7b820e000-7fe7b820f000 r-xs 00000000 08:01 5964383                    /var/subsonic/jetty/webapp/script/fancyzoom/images/zoom-shadow6.png
7fe7b820f000-7fe7b8210000 r-xs 00000000 08:01 5964382                    /var/subsonic/jetty/webapp/script/fancyzoom/images/zoom-shadow5.png
7fe7b8210000-7fe7b8211000 r-xs 00000000 08:01 5964381                    /var/subsonic/jetty/webapp/script/fancyzoom/images/zoom-shadow4.png
7fe7b8211000-7fe7b8212000 r-xs 00000000 08:01 5964380                    /var/subsonic/jetty/webapp/script/fancyzoom/images/zoom-shadow3.png
7fe7b8212000-7fe7b8213000 r-xs 00000000 08:01 5964373                    /var/subsonic/jetty/webapp/script/fancyzoom/images/closebox.png
7fe7b8213000-7fe7b8214000 r-xs 00000000 08:01 5964379                    /var/subsonic/jetty/webapp/script/fancyzoom/images/zoom-shadow2.png
7fe7b8214000-7fe7b8215000 r-xs 00000000 08:01 5964378                    /var/subsonic/jetty/webapp/script/fancyzoom/images/zoom-shadow1.png
7fe7b8215000-7fe7b8216000 r-xs 00000000 08:01 5964374                    /var/subsonic/jetty/webapp/script/fancyzoom/images/spacer.gif
7fe7b8216000-7fe7b8217000 r-xs 00000000 08:01 5964386                    /var/subsonic/jetty/webapp/script/fancyzoom/images/zoom-spin-1.png
7fe7b8217000-7fe7b8218000 r-xs 00000000 08:01 5964268                    /var/subsonic/jetty/webapp/icons/midnight/back.png
7fe7b8218000-7fe7b8219000 r-xs 00000000 08:01 5964258                    /var/subsonic/jetty/webapp/icons/download.gif
7fe7b8219000-7fe7b821a000 r-xs 00000000 08:01 5964213                    /var/subsonic/jetty/webapp/icons/add.gif
7fe7b821a000-7fe7b821b000 r-xs 00000000 08:01 5964313                    /var/subsonic/jetty/webapp/icons/play.gif
7fe7b821b000-7fe7b821c000 r-xs 00000000 08:01 5964215                    /var/subsonic/jetty/webapp/icons/clearRating.png
7fe7b821c000-7fe7b821d000 r-xs 00000000 08:01 5964319                    /var/subsonic/jetty/webapp/icons/ratingOff.png
7fe7b821d000-7fe7b821e000 r-xs 00000000 08:01 5964311                    /var/subsonic/jetty/webapp/icons/now_playing.png
7fe7b821e000-7fe7b8221000 r-xs 00000000 08:01 5964372                    /var/subsonic/jetty/webapp/script/fancyzoom/FancyZoomHTML.js
7fe7b8221000-7fe7b8227000 r-xs 00000000 08:01 5964371                    /var/subsonic/jetty/webapp/script/fancyzoom/FancyZoom.js
7fe7b8227000-7fe7b8228000 r-xs 00000000 08:01 5964401                    /var/subsonic/jetty/webapp/script/scripts.js
7fe7b8228000-7fe7b8235000 r-xs 00000000 08:01 5964212                    /var/subsonic/jetty/webapp/flash/jw-player-4.4.swf
7fe7b8235000-7fe7b823c000 r-xs 00091000 08:01 2728435                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/jsse.jar
7fe7b823c000-7fe7b823d000 r-xs 00000000 08:01 5964210                    /var/subsonic/jetty/webapp/ad/omakasa.html
7fe7b823d000-7fe7b823e000 ---p 7fe7b823d000 00:00 0
7fe7b823e000-7fe7b833e000 rwxp 7fe7b823e000 00:00 0
7fe7b833e000-7fe7b8341000 ---p 7fe7b833e000 00:00 0
7fe7b8341000-7fe7b843f000 rwxp 7fe7b8341000 00:00 0
7fe7b843f000-7fe7b8442000 ---p 7fe7b843f000 00:00 0
7fe7b8442000-7fe7b8540000 rwxp 7fe7b8442000 00:00 0
7fe7b8540000-7fe7b8543000 ---p 7fe7b8540000 00:00 0
7fe7b8543000-7fe7b8641000 rwxp 7fe7b8543000 00:00 0
7fe7b8641000-7fe7b8644000 ---p 7fe7b8641000 00:00 0
7fe7b8644000-7fe7b8742000 rwxp 7fe7b8644000 00:00 0
7fe7b8742000-7fe7b8781000 r-xp 00000000 08:01 2376621                    /usr/lib/locale/en_US.utf8/LC_CTYPE
7fe7b8781000-7fe7b8784000 ---p 7fe7b8781000 00:00 0
7fe7b8784000-7fe7b8882000 rwxp 7fe7b8784000 00:00 0
7fe7b8882000-7fe7b8885000 ---p 7fe7b8882000 00:00 0
7fe7b8885000-7fe7b8983000 rwxp 7fe7b8885000 00:00 0
7fe7b8983000-7fe7b8984000 ---p 7fe7b8983000 00:00 0
7fe7b8984000-7fe7b8ab7000 rwxp 7fe7b8984000 00:00 0
7fe7b8ab7000-7fe7b8c49000 r-xs 02f34000 08:01 2728619                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/rt.jar
7fe7b8c49000-7fe7b8c4a000 ---p 7fe7b8c49000 00:00 0
7fe7b8c4a000-7fe7b8d4a000 rwxp 7fe7b8c4a000 00:00 0
7fe7b8d4a000-7fe7b8d4b000 ---p 7fe7b8d4a000 00:00 0
7fe7b8d4b000-7fe7b8e65000 rwxp 7fe7b8d4b000 00:00 0
7fe7b8e65000-7fe7b8e75000 rwxp 7fe7b8e65000 00:00 0
7fe7b8e75000-7fe7b8e8f000 rwxp 7fe7b8e75000 00:00 0
7fe7b8e8f000-7fe7b8e9f000 rwxp 7fe7b8e8f000 00:00 0
7fe7b8e9f000-7fe7b8eac000 rwxp 7fe7b8e9f000 00:00 0
7fe7b8eac000-7fe7b8eb4000 rwxp 7fe7b8eac000 00:00 0
7fe7b8eb4000-7fe7b8ebf000 rwxp 7fe7b8eb4000 00:00 0
7fe7b8ebf000-7fe7bc220000 rwxp 7fe7b8ebf000 00:00 0
7fe7bc220000-7fe7be2c0000 rwxp 7fe7bc220000 00:00 0
7fe7be2c0000-7fe7bfbd0000 rwxp 7fe7be2c0000 00:00 0
7fe7bfbd0000-7fe7c0d70000 rwxp 7fe7bfbd0000 00:00 0
7fe7c0d70000-7fe7c21e0000 rwxp 7fe7c0d70000 00:00 0
7fe7c21e0000-7fe7c22c0000 rwxp 7fe7c21e0000 00:00 0
7fe7c22c0000-7fe7c22c1000 r-xs 00000000 08:01 5964400                    /var/subsonic/jetty/webapp/script/scriptaculous.js
7fe7c22c1000-7fe7c22c6000 r-xs 00040000 08:01 5964854                    /var/subsonic/jetty/webapp/WEB-INF/lib/commons-httpclient-3.0.1.jar
7fe7c22c6000-7fe7c2746000 rwxp 7fe7c22c6000 00:00 0
7fe7c2746000-7fe7c52c6000 rwxp 7fe7c2746000 00:00 0
7fe7c52c6000-7fe7c52d4000 r-xp 00000000 08:01 2736145                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libzip.so
7fe7c52d4000-7fe7c53d6000 ---p 0000e000 08:01 2736145                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libzip.so
7fe7c53d6000-7fe7c53d9000 rwxp 00010000 08:01 2736145                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libzip.so
7fe7c53d9000-7fe7c53da000 rwxp 7fe7c53d9000 00:00 0
7fe7c53da000-7fe7c5403000 r-xp 00000000 08:01 2736158                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libjava.so
7fe7c5403000-7fe7c5502000 ---p 00029000 08:01 2736158                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libjava.so
7fe7c5502000-7fe7c5509000 rwxp 00028000 08:01 2736158                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libjava.so
7fe7c5509000-7fe7c5516000 r-xp 00000000 08:01 2736140                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libverify.so
7fe7c5516000-7fe7c5615000 ---p 0000d000 08:01 2736140                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libverify.so
7fe7c5615000-7fe7c5618000 rwxp 0000c000 08:01 2736140                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/libverify.so
7fe7c5618000-7fe7c5624000 r-xp 00000000 08:01 16506965                   /lib/libnss_files-2.9.so
7fe7c5624000-7fe7c5823000 ---p 0000c000 08:01 16506965                   /lib/libnss_files-2.9.so
7fe7c5823000-7fe7c5824000 r-xp 0000b000 08:01 16506965                   /lib/libnss_files-2.9.so
7fe7c5824000-7fe7c5825000 rwxp 0000c000 08:01 16506965                   /lib/libnss_files-2.9.so
7fe7c5825000-7fe7c582f000 r-xp 00000000 08:01 16506975                   /lib/libnss_nis-2.9.so
7fe7c582f000-7fe7c5a2e000 ---p 0000a000 08:01 16506975                   /lib/libnss_nis-2.9.so
7fe7c5a2e000-7fe7c5a2f000 r-xp 00009000 08:01 16506975                   /lib/libnss_nis-2.9.so
7fe7c5a2f000-7fe7c5a30000 rwxp 0000a000 08:01 16506975                   /lib/libnss_nis-2.9.so
7fe7c5a30000-7fe7c5a38000 r-xp 00000000 08:01 16506961                   /lib/libnss_compat-2.9.so
7fe7c5a38000-7fe7c5c37000 ---p 00008000 08:01 16506961                   /lib/libnss_compat-2.9.so
7fe7c5c37000-7fe7c5c38000 r-xp 00007000 08:01 16506961                   /lib/libnss_compat-2.9.so
7fe7c5c38000-7fe7c5c39000 rwxp 00008000 08:01 16506961                   /lib/libnss_compat-2.9.so
7fe7c5c39000-7fe7c5c4f000 r-xp 00000000 08:01 16506959                   /lib/libnsl-2.9.so
7fe7c5c4f000-7fe7c5e4f000 ---p 00016000 08:01 16506959                   /lib/libnsl-2.9.so
7fe7c5e4f000-7fe7c5e50000 r-xp 00016000 08:01 16506959                   /lib/libnsl-2.9.so
7fe7c5e50000-7fe7c5e51000 rwxp 00017000 08:01 16506959                   /lib/libnsl-2.9.so
7fe7c5e51000-7fe7c5e53000 rwxp 7fe7c5e51000 00:00 0
7fe7c5e53000-7fe7c5e5a000 r-xp 00000000 08:01 2736147                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/native_threads/libhpi.so
7fe7c5e5a000-7fe7c5f5b000 ---p 00007000 08:01 2736147                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/native_threads/libhpi.so
7fe7c5f5b000-7fe7c5f5d000 rwxp 00008000 08:01 2736147                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/native_threads/libhpi.so
7fe7c5f5d000-7fe7c5f5e000 rwxp 7fe7c5f5d000 00:00 0
7fe7c5f5e000-7fe7c5f65000 r-xp 00000000 08:01 16507003                   /lib/librt-2.9.so
7fe7c5f65000-7fe7c6164000 ---p 00007000 08:01 16507003                   /lib/librt-2.9.so
7fe7c6164000-7fe7c6165000 r-xp 00006000 08:01 16507003                   /lib/librt-2.9.so
7fe7c6165000-7fe7c6166000 rwxp 00007000 08:01 16507003                   /lib/librt-2.9.so
7fe7c6166000-7fe7c6169000 ---p 7fe7c6166000 00:00 0
7fe7c6169000-7fe7c6267000 rwxp 7fe7c6169000 00:00 0
7fe7c6267000-7fe7c62eb000 r-xp 00000000 08:01 16506952                   /lib/libm-2.9.so
7fe7c62eb000-7fe7c64ea000 ---p 00084000 08:01 16506952                   /lib/libm-2.9.so
7fe7c64ea000-7fe7c64eb000 r-xp 00083000 08:01 16506952                   /lib/libm-2.9.so
7fe7c64eb000-7fe7c64ec000 rwxp 00084000 08:01 16506952                   /lib/libm-2.9.so
7fe7c64ec000-7fe7c6b79000 r-xp 00000000 08:01 2736165                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/server/libjvm.so
7fe7c6b79000-7fe7c6c78000 ---p 0068d000 08:01 2736165                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/server/libjvm.so
7fe7c6c78000-7fe7c6dc9000 rwxp 0068c000 08:01 2736165                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/server/libjvm.so
7fe7c6dc9000-7fe7c6e06000 rwxp 7fe7c6dc9000 00:00 0
7fe7c6e06000-7fe7c6f6e000 r-xp 00000000 08:01 16506919                   /lib/libc-2.9.so
7fe7c6f6e000-7fe7c716e000 ---p 00168000 08:01 16506919                   /lib/libc-2.9.so
7fe7c716e000-7fe7c7172000 r-xp 00168000 08:01 16506919                   /lib/libc-2.9.so
7fe7c7172000-7fe7c7173000 rwxp 0016c000 08:01 16506919                   /lib/libc-2.9.so
7fe7c7173000-7fe7c7178000 rwxp 7fe7c7173000 00:00 0
7fe7c7178000-7fe7c717a000 r-xp 00000000 08:01 16506933                   /lib/libdl-2.9.so
7fe7c717a000-7fe7c737a000 ---p 00002000 08:01 16506933                   /lib/libdl-2.9.so
7fe7c737a000-7fe7c737b000 r-xp 00002000 08:01 16506933                   /lib/libdl-2.9.so
7fe7c737b000-7fe7c737c000 rwxp 00003000 08:01 16506933                   /lib/libdl-2.9.so
7fe7c737c000-7fe7c7393000 r-xp 00000000 08:01 16506997                   /lib/libpthread-2.9.so
7fe7c7393000-7fe7c7592000 ---p 00017000 08:01 16506997                   /lib/libpthread-2.9.so
7fe7c7592000-7fe7c7593000 r-xp 00016000 08:01 16506997                   /lib/libpthread-2.9.so
7fe7c7593000-7fe7c7594000 rwxp 00017000 08:01 16506997                   /lib/libpthread-2.9.so
7fe7c7594000-7fe7c7598000 rwxp 7fe7c7594000 00:00 0
7fe7c7598000-7fe7c75b8000 r-xp 00000000 08:01 16506899                   /lib/ld-2.9.so
7fe7c75b8000-7fe7c75ba000 r-xs 00000000 08:01 5964429                    /var/subsonic/jetty/webapp/style/default.css
7fe7c75ba000-7fe7c75c7000 rwxp 7fe7c75ba000 00:00 0
7fe7c75c7000-7fe7c75d0000 rwxp 7fe7c75c7000 00:00 0
7fe7c75d0000-7fe7c75e2000 rwxp 7fe7c75d0000 00:00 0
7fe7c75e2000-7fe7c7690000 rwxp 7fe7c75e2000 00:00 0
7fe7c7690000-7fe7c7692000 rwxp 7fe7c7690000 00:00 0
7fe7c7692000-7fe7c7699000 r-xp 00000000 08:01 2736131                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/jli/libjli.so
7fe7c7699000-7fe7c779a000 ---p 00007000 08:01 2736131                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/jli/libjli.so
7fe7c779a000-7fe7c779c000 rwxp 00008000 08:01 2736131                    /usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/jli/libjli.so
7fe7c779c000-7fe7c779d000 rwxp 7fe7c779c000 00:00 0
7fe7c779d000-7fe7c779e000 r-xs 00000000 08:01 5964439                    /var/subsonic/jetty/webapp/style/shadow.css
7fe7c779e000-7fe7c779f000 r-xs 00000000 08:01 5964435                    /var/subsonic/jetty/webapp/style/midnight.css
7fe7c779f000-7fe7c77a1000 r-xs 00006000 08:01 5964850                    /var/subsonic/jetty/webapp/WEB-INF/lib/commons-codec-1.2.jar
7fe7c77a1000-7fe7c77a3000 r-xs 00000000 08:01 5964845                    /var/subsonic/jetty/webapp/WEB-INF/lib/aopalliance-1.0.jar
7fe7c77a3000-7fe7c77aa000 r-xs 00000000 08:01 16171251                   /usr/lib/gconv/gconv-modules.cache
7fe7c77aa000-7fe7c77b2000 rwxs 00000000 08:01 10698765                   /tmp/hsperfdata_root/4619
7fe7c77b2000-7fe7c77b3000 rwxp 7fe7c77b2000 00:00 0
7fe7c77b3000-7fe7c77b4000 r-xp 7fe7c77b3000 00:00 0
7fe7c77b4000-7fe7c77b7000 rwxp 7fe7c77b4000 00:00 0
7fe7c77b7000-7fe7c77b8000 r-xp 0001f000 08:01 16506899                   /lib/ld-2.9.so
7fe7c77b8000-7fe7c77b9000 rwxp 00020000 08:01 16506899                   /lib/ld-2.9.so
7fffcf7a4000-7fffcf7b9000 rwxp 7ffffffea000 00:00 0                      [stack]
7fffcf7ff000-7fffcf800000 r-xp 7fffcf7ff000 00:00 0                      [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0                  [vsyscall]
VM Arguments:
jvm_args: -Xmx64m -Dsubsonic.home=/var/subsonic -Dsubsonic.host=0.0.0.0 -Dsubsonic.port=8080 -Dsubsonic.contextPath=/
java_command: subsonic-booter-jar-with-dependencies.jar
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/X11R6/bin
USERNAME=root
LD_LIBRARY_PATH=/usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64/server:/usr/lib/jvm/java-6-sun-1.6.0.13/jre/lib/amd64:/usr/lib/jvm/java-6-sun-1.6.0.13/jre/../lib/amd64
SHELL=/bin/bash
Signal Handlers:
SIGSEGV: [libjvm.so+0x5fcd20], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGBUS: [libjvm.so+0x5fcd20], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGFPE: [libjvm.so+0x4e0eb0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGPIPE: [libjvm.so+0x4e0eb0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGXFSZ: [libjvm.so+0x4e0eb0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGILL: [libjvm.so+0x4e0eb0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR2: [libjvm.so+0x4e35d0], sa_mask[0]=0x00000000, sa_flags=0x10000004
SIGHUP: [libjvm.so+0x4e3320], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGINT: SIG_IGN, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGTERM: [libjvm.so+0x4e3320], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGQUIT: [libjvm.so+0x4e3320], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
---------------  S Y S T E M  ---------------
OS:5.0
uname:Linux 2.6.28-11-generic #42-Ubuntu SMP Fri Apr 17 01:58:03 UTC 2009 x86_64
libc:glibc 2.9 NPTL 2.9
rlimit: STACK 8192k, CORE 0k, NPROC infinity, NOFILE 1024, AS infinity
load average:0.10 0.03 0.01
CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 15 stepping 2, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3
Memory: 4k page, physical 2033744k(1490328k free), swap 5952040k(5952040k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (11.3-b02) for linux-amd64 JRE (1.6.0_13-b03), built on Mar  9 2009 11:08:22 by "java_re" with gcc 3.2.2 (SuSE Linux)
time: Tue Jun  9 09:27:41 2009
elapsed time: 3925 seconds
geiman
