Streaming same content to 3 computer simultaneously
Postby laroux » Sat Jun 27, 2009 6:28 pm
Hi, this is probably a dumb question but I have been trying to figure it out for hours with no success. I'm having a party and want to stream the same music to three different computers hooked to three different stereo systems in my house at the same time. I try to select the same play from each computer and I can hear it play on the server but no joy until I hit the play button on the local machine, and then it's out of synch with the server. Please help.
laroux
Postby sindre_mehus » Sun Jun 28, 2009 10:37 am
Sorry, that's not possible in Subsonic.
Postby deriksen » Sun Jun 28, 2009 12:53 pm
It will be however, once we get Subsonic to broadcast over the Slimserver protocol (ref http://forum.subsonic.org/forum/viewtopic.php?t=1914). Of course, you'll need to buy a couple of Squeezebox receivers, but it would be oooh so sweet! :D
deriksen
Postby BrianDelShasta » Sun Jun 28, 2009 2:00 pm
If the server you have has a soundcard you can do this right now by just throwing vlc into the mix (or any other streaming server):
1) install vlc on your subsonic server
2) use subsonic's jukebox feature to allow a shared playlist to play sound output on the server
3) open vlc and setup a stream under media>streaming>capture device
4) select your audio device and setup a directshow stream
5) finally, use vlc, winamp, etc to connect to the vlc stream
This essentially acts like an internet radio station but any computer can adjust the playlist for the jukebox if you desire.
BrianDelShasta
Postby deriksen » Sun Jun 28, 2009 6:44 pm
Good post Brian! :)
deriksen
streaming the audio signal with VLC
Postby selectabence » Tue Oct 06, 2009 9:00 pm
Hi Brian! thanks for this idea!
I tried to get this running - but up to now failed.
Can you give a little more info on how to choose the VLC streaming settings?
I know that it would probably need to be set to RTP in Outputs - right?
I used the subsonic jukebox feature with the result, that sound suddenly came out of the USB headset...
I managed to set up the VLC capture device (I chose the Headset, since that was where the sound came out) and VLC told me that it was "streaming".
but - where to?
How should I configure the Output? only one IP address? port 1234? will that need port forwarding again too?
what is the "generated stream output string" good for? if VLC is streaming to say:
RTP 91.115.169.198 Port 1234
what will the user with this RTP Adress have to do, to actually receive this stream and be able to listen to it?
Your advice is very much appreciated!!!
streamy dreams
selectabence
Users browsing this forum: No registered users and 104 guests
