LAME
LAME
Postby HiSpeed » Wed Dec 21, 2005 2:46 pm
Hi.
I have problem with my Lame installation. I have installed RazorLime but it doesn’t work under Subsonic!? I have also copied the lame_enc.dll to c:\windows but it still doesn’t work. :cry:
What have I done wrong?
HiSpeed
Postby sindre_mehus » Thu Dec 22, 2005 8:27 am
RazorLame is graphical frontend to LAME, and is not relevant to Subsonic. The important thing is that LAME is installed properly. Have you copied lame.exe to c:\windows?
I suggest you do the following: Install the bugfix release found at http://www.activeobjects.no/subsonic/download/subsonic-2.5-bugfix3.zip. It fixes a problem with running LAME on Linux, as well as providing more diagnostics.
Then watch the Subsonic log while it resamples the mp3 files. (The log is located on the "Help" page, and can also be found in C:\Program Files\Apache Software Foundation\Tomcat 5.5\logs\subsonic.log) Please post the result here, and I might be able to help you further.
Note that resampling is only supported for constant bitrate mp3 (not variable bitrate).
Postby HiSpeed » Thu Dec 22, 2005 11:58 am
It works :D
I copied LAME.EXE and lame_enc.dll to C:\Windows.
HiSpeed
Users browsing this forum: No registered users and 70 guests
