Skipping through tracks in Jukebox mode
Postby tommyperkins » Thu Jul 02, 2009 9:30 pm
I waited for the release of 3.7 before installing as the Jukebox mode is something that I was after.
Is there a way of skipping within songs through a browser whilst the music is playing on the server?
Most of my music come in mixes (long single tracks) and so this is would be really handy.
Thanks and great work! :D
tommyperkins
Postby sindre_mehus » Fri Jul 03, 2009 4:36 am
Sorry, that's not possible.
Postby tommyperkins » Sat Jul 04, 2009 6:46 am
Is this easy to implement and could it be included in a future release? :wink:
If not does anyone know any work arounds?
Thanks.
tommyperkins
Postby sindre_mehus » Sat Jul 04, 2009 8:02 am
It's not that easy to implement, mostly due to the fact that the player control (progress slider etc) and the actual player are on two different computers.
I agree that it would be nice to have, but it won't be prioritized for the next few releases, unfortunately.
Postby nublet » Sun Jul 12, 2009 11:22 pm
do most of these long mixes in single track include a .cue file form wherever you obtain them ? :wink:
if so there is an easy workaround for you :D
http://www.medieval.it/content/view/28/71/
Have used it for years will spit out the individual tracks of the mix in just a few secs and is very customizable as far as the output tags ... works great on them MOS albums and such...
hope this helps
nublet
Postby tommyperkins » Wed Jul 15, 2009 3:48 pm
They don't unfortunately. Does this software just create another folder with the amount of tracks contained within the CUE sheet? If so then this would use double the disk space since I'd have one big mix (which I'd prefer to keep) and then the mix cut into however many track.
Can Subsonic read from CUE sheets by any chance? I could then create one using some software (name all the tracks the same) and put it into the music directory.
tommyperkins
Users browsing this forum: No registered users and 62 guests
