Help setting up access from internet
Postby UsR H BOMB » Fri Jul 03, 2009 1:05 pm
First time posting here. Thanks for great app.
I have managed to Setup Subsonic no problem also a account with no-ip. My networking knowledge is a bit basic and don't know how to setup access from the internet.
Any help would be appreciated
UsR H BOMB
Postby donpearson » Fri Jul 03, 2009 5:10 pm
if its 80 or whatever port you have it on, you have to set your router up (if your using one) to forward to the port subsonic is running on to the pc its running on.... if you get me?
then all you have to do is call up the address you have and there you will have subsonic up and running...
if your using a port other then 80 ie 8080 then you will have to call up your addres with www.address.com:8080
Facebook Group:
donpearson
Postby UsR H BOMB » Fri Jul 03, 2009 8:53 pm
I put in my external ip address on my no-ip account and set redirect port 80 to port 6000. I set my router to open port 6000 for my pc's ip address also subsonic is set to port 6000. Still not working what am i doing wrong?
UsR H BOMB
Postby donpearson » Sat Jul 04, 2009 10:45 am
pm me the addres to your sever so i can have a look, some times on systems you cant use the main web address to get in to it... just like mine.
Facebook Group:
donpearson
Postby oxide[NL] » Fri Jul 10, 2009 1:48 pm
got something for that ;)
http://anonymouse.org
type in your url ( or ip ) walla
oxide[NL]
