Stats not always displayed - 3.7
Postby guitargurus » Wed Jul 08, 2009 1:19 pm
Since upgrading to 3.7, sometimes my stats show, some times they do not (stats being # of albums, songs, size, etc). When initiating a manual search index, sometimes (after a few hours), the stats will display. They will continue to show up until the schedule index runs again, then they disappear and I have to initiate a manual index again.
Any ideas? There is about 500GB of All-FLAC music. Maybe 1300 albums or so.
Thanks is advance,
Mike
guitargurus
Postby donpearson » Thu Jul 09, 2009 3:16 pm
Iv had this same problem.
The way i fixed it was to increase the size if the memory that subsonic uses.
Iv set mine to 192.
give that a go and see if it helps.
Facebook Group:
donpearson
Postby guitargurus » Fri Jul 10, 2009 12:39 pm
I'll give it a shot. Thx.
Do you know if there is any downside to setting it even higher? Say, 512? The server has 8GB Ram.
Mike
guitargurus
Postby donpearson » Fri Jul 10, 2009 12:45 pm
Not with the ram you have.
If you set it to 512 you should fined it all running very nice for you.
Facebook Group:
donpearson
