help installing
help installing
Postby dba61 » Sun Jul 12, 2009 2:45 am
I'm a newbie to Linux and Subsonic. Could any one please give a step by step instruction on installing the software. I am using Fedora 11 and have both Apache and jetty installed. I thought I followed the instructions correctly, but since nothing works I made a mistake(s) somewhere.
Another question is once it is up and running how would I go about creating a password file for multiple users and expirations times and setting it up to be accessed through DynDNS?
Thank you,
Danny
dba61
Postby donpearson » Sun Jul 12, 2009 8:00 am
why dont you use the windows install if you not to sure ?
Facebook Group:
donpearson
Re: help installing
Postby jigsaw » Sun Jul 12, 2009 2:29 pm
dba61 wrote:I'm a newbie to Linux and Subsonic. Could any one please give a step by step instruction on installing the software. I am using Fedora 11 and have both Apache and jetty installed. I thought I followed the instructions correctly, but since nothing works I made a mistake(s) somewhere.
Did you follow the tutorial at the Subsonic Homepage? (http://subsonic.sourceforge.net/install ... standalone) - assuming you are using the standalone installation as you are talking about Jetty.
What seems to be the issue? I am running the standalone version on F11 without any problems. It's running through a proxy on Apache and mounted all my media from a windows host over samba :)
For some info on how to set it up to run as a service, that way you do not need to manually run the subsonic.sh every time you reboot the server, you can read this: http://forum.subsonic.org/forum/viewtopic.php?t=1634
dba61 wrote:Another question is once it is up and running how would I go about creating a password file for multiple users and expirations times and setting it up to be accessed through DynDNS?
Subsonic has all it's users in the local database and there's no expiration feature ( a cool idea though, maybe you should post it as a feature request :) ).
Regarding DynDNS I am not using that myself ( I'm using no-ip.org ), but I searched in the forum and found this thread that should cover the most of it: http://forum.subsonic.org/forum/viewtop ... ght=dyndns
-jigsaw
jigsaw
donpearson wrote:why dont you use the windows install if you not to sure ?
It normally doesn't work too well on Linux... ;)
jigsaw
