Namespace exception
Namespace exception
Postby OliverJones1323 » Wed Jul 15, 2009 3:52 pm
Hi all
I'm getting the exception below on a web site hosted by Fasthosts which all of a sudden started throwing the exception below. Editing web.config fixes it, presumably by recycling the app.
However every 2 weeks or so it does it again. Any ideas anyone?
The given name 'NHSSBS' matches at least two names in the collection object with different namespaces.
Line 32: string pageDatabasePath = SiteStructure.GetDatabasePath(Request.AppRelativeCurrentExecutionFilePath);
Line 33:
Line 34: SubSonic.Query query = new SubSonic.Query("Metatag");
Line 35: query.QueryType = SubSonic.QueryType.Select;
Line 36: query.WHERE("Path", pageDatabasePath);
Source File: e:\DOMAINS\s\sbs.nhs.uk\user\htdocs\UserControls\HTMLHead.ascx.cs Line: 34
Stack Trace:
[ArgumentException: The given name 'NHSSBS' matches at least two names in the collection object with different namespaces.]
System.Data.DataTableCollection.get_Item(String name) +1770251
SubSonic.SqlDataProvider.GetTableSchema(String tableName, TableType tableType) in C:\Program Files\SubSonic\SubSonic 2.0.3\src\SubSonic\DataProviders\SqlDataProvider.cs:430
SubSonic.DataService.GetSchema(String tableName, String providerName, TableType tableType) in C:\Program Files\SubSonic\SubSonic 2.0.3\src\SubSonic\DataProviders\DataService.cs:426
SubSonic.DataService.GetTableSchema(String tableName, String providerName) in C:\Program Files\SubSonic\SubSonic 2.0.3\src\SubSonic\DataProviders\DataService.cs:440
SubSonic.Query.BuildTableSchema(String tableName, String providerName) in C:\Program Files\SubSonic\SubSonic 2.0.3\src\SubSonic\Sql Tools\Query.cs:497
SubSonic.Query.BuildTableSchema(String tableName) in C:\Program Files\SubSonic\SubSonic 2.0.3\src\SubSonic\Sql Tools\Query.cs:492
SubSonic.Query..ctor(String tableName) in C:\Program Files\SubSonic\SubSonic 2.0.3\src\SubSonic\Sql Tools\Query.cs:651
UserControls_HTMLHead.SetupMetatags() in e:\DOMAINS\s\sbs.nhs.uk\user\htdocs\UserControls\HTMLHead.ascx.cs:34
UserControls_HTMLHead.Page_Load(Object sender, EventArgs e) in e:\DOMAINS\s\sbs.nhs.uk\user\htdocs\UserControls\HTMLHead.ascx.cs:27
System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
System.Web.UI.Control.OnLoad(EventArgs e) +99
System.Web.UI.Control.LoadRecursive() +50
System.Web.UI.Control.LoadRecursive() +141
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
OliverJones1323
