Default User Permissions
Postby tguidry » Mon Jul 20, 2009 5:38 pm
I have successfully tied subsonic into Active Directory for user authentication.
When a new user logs in for the first time it creates a local subsonic account. I would like to modify the default permission it creates. I would like to have users be able to download files by default.
Where can I make these adjustments.
Thanks for your work on this great product.
tguidry
Postby pkx » Sun Jan 02, 2011 6:45 am
Bumping an old thread... I'm trying to figure this out as well.
pkx
Re: Default User Permissions
Postby trogdan » Wed Sep 26, 2012 3:19 pm
third bump. I too use active directory with a number of users. It's a pain to manually reset each individual user to grant additional privileges.
I did find a thread on granting permissions in bulk, but that's it
trogdan
Postby bushman4 » Wed Sep 26, 2012 3:36 pm
There is no built in functionality to do what you want. You could take a look at the source code, or make a feature request for potential inclusion into a future version.
but right now there is no easy way to accomplish what you desire.
Sorry,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby lovebags » Sun May 08, 2016 10:28 pm
This is still something that can't be done from the main interface but there is a workaround as follows that we use: here is an example of giving all users download access.
Access the /db.view page from your domain then enter the following commands into the text box:
delete from user_role where role_id = 2
Press “ok” then type
insert into user_role (username, role_id) select distinct(username), 2 from user_role
Press “ok”
I don't have a list of all the other roles but I do know changing cover art is role_id = 5
lovebags
