Adding Additional HTM Page
Postby dwmd65 » Tue Jul 28, 2009 11:45 pm
I would like to add a page that I will link from the main page but am not sure where to place the file in windows.
dwmd65
Postby donpearson » Wed Jul 29, 2009 5:15 pm
that depends on what webserver you are running on where you put it.
Facebook Group:
donpearson
Version
Postby dwmd65 » Thu Jul 30, 2009 6:49 pm
Version 3.7 (build 898) – June 15, 2009
Server jetty-6.1.x, java 1.6.0_05, Windows XP (66.8 MB / 178.3 MB)
Does this help?
Dave
dwmd65
Postby donpearson » Thu Jul 30, 2009 6:52 pm
look in to Apache.
just google it, you are best off setting that up first.
Facebook Group:
donpearson
Postby jonathanroz » Thu Jul 30, 2009 9:05 pm
Are you looking to have a link within the subsonic interface that links to another page? Does that page already exist?
jonathanroz
Postby dwmd65 » Thu Jul 30, 2009 9:12 pm
Yes, just a link from the main page and yes it does it exist. Just don't know where to place the file. I am used to IIS.
What is the benefit of installing apache?
What web server is subsonic running by default?
Thanks for the help.
dwmd65
Postby jonathanroz » Fri Jul 31, 2009 2:03 pm
Well you can just put your webpage in the subsonic\jetty\webapp\ folder where index.html is and then point your browser to the same url as you go to subsonic with but replace the end of the URL with the name of the page.
So http://mysite:88/subsonic/main.html instead of http://mysite:88/subsonic/index.view?
I tested this and it does work.
jonathanroz
Postby donpearson » Fri Jul 31, 2009 2:58 pm
if you install apache you can then use ssl as well.
but you can do that using iis.
but then iis is really bad.
Facebook Group:
donpearson
Error
Postby dwmd65 » Fri Jul 31, 2009 6:59 pm
Interesting. That is what I was trying and it failed so I assumed I was placing it in the wrong folder.
If I put a txt file in there it works but if I place an htm or html file in there I get a jetty error.
HTTP ERROR: 404
NOT_FOUND
RequestURI=/new.html
Powered by Jetty://
Any ideas?
Dave
dwmd65
Postby jonathanroz » Fri Jul 31, 2009 9:35 pm
Honestly I am not sure why you would get that error. You are reaching the Jetty service so you would think the file should be delivered if it is under the right name.
If I type the name of a file that doesnt exist in that folder I get
HTTP ERROR: 404
NOT_FOUND
RequestURI=/music/poo.html
Powered by Jetty://
but if I put the correct path it works fine.
I agree with Don that Apache gives you a lot more flexability. I also run it and use the proxy service like Don does. I haven't taken the time to go SSL yet.... :)
jonathanroz
