Can't install on another drive letter that is not c
Postby tegra » Mon Aug 03, 2009 7:30 pm
When I Install Subsonic on another drive that is not c drive it gives me problems. For example in the install it says.
ERROR OPENING FILE FOR WRITING:
C:\SUBSONIC\TRANSCODE\README.TXT
ABORT RETRY OR IGNORE.
The problem is that my windows is located in my E:\ drive not c: So I then how can I get this working. This happens even though I said it to install in my e:\program files\subsonic
tegra
Postby jonathanroz » Mon Aug 03, 2009 8:13 pm
If you look under -->> Program Files\subsonic there is a file named subsonic-service.exe.vmoptions
Open that file with a text editor (I prefer Notepad++) and add the below line at the end of the file.
-Dsubsonic.home=d:/subsonic
of course you can make it e:/subsonic or whatever you full path is.
Hit Save and Reboot
jonathanroz
