Subsonic (with apache tomcat) Stopped working
Postby gerstejp » Fri Aug 07, 2009 3:57 pm
I am running the .war version of Subsonic through apache tomcat 6 on my windows home server. The service was running flawlessly but is now offline. The server power cycled but I otherwise didnt make any changes and cannot figure out how to get it started. Any advice would be greatly appreciated.
J
Here are some things i think might be important to know:
1) Apache tomcat 6 is installed and the service says it is "started"
2) I can access the localhost portal when remote desktop connected to the server
3) i cannot access the service from any other computer intranet or internet
4) Windows home server appears to have virus protection through the other networked computers directly attached to the same router...not sure how or why but when you turn off malware for the master computer, the whs pc gives a warning message that it isnt protected. I recently updated the master pc to windows 7 RC and changed the malware protection from live one care to panda security.
gerstejp
Postby flacflac » Sun Aug 09, 2009 10:16 pm
Sounds like either a firewall issue or a port forwarding issue through your router. What port are you running subsonic on? Have you tried using it with the firewall completely turned off?
ff
flacflac
