Error HTTP ERROR: 404 NOT_FOUND RequestURI=/index.view
Postby tegra » Fri Aug 07, 2009 5:44 pm
I know get this error. On my Windows Xp Pro.
HTTP ERROR: 404
NOT_FOUND
Powered by Jetty://
Please help
tegra
Postby donpearson » Sat Aug 08, 2009 7:56 am
Have you changed any setting in subsonic?
Facebook Group:
donpearson
Postby tegra » Sat Aug 08, 2009 2:04 pm
donpearson wrote:Have you changed any setting in subsonic?
Yes added this. -Dsubsonic.home=e:/subsonic I had posted about.
When I Install Subsonic on another drive that is not c drive it gives me problems. For example in the install it says.
ERROR OPENING FILE FOR WRITING:
C:\SUBSONIC\TRANSCODE\README.TXT
ABORT RETRY OR IGNORE.
The problem is that my windows is located in my E:\ drive not c: So I then how can I get this working. This happens even though I said it to install in my e:\program files\subsonic
So then he told me to do this.
If you look under -->> Program Files\subsonic there is a file named subsonic-service.exe.vmoptions
Open that file with a text editor (I prefer Notepad++) and add the below line at the end of the file.
-Dsubsonic.home=d:/subsonic
of course you can make it e:/subsonic or whatever you full path is.
Hit Save and Reboot
Thats all I have done
tegra
Postby donpearson » Sat Aug 08, 2009 3:46 pm
How are you calling up the url? and are you using the right port number as well?
Facebook Group:
donpearson
Postby tegra » Sat Aug 08, 2009 5:33 pm
donpearson wrote:How are you calling up the url? and are you using the right port number as well?
I tried http://localhost and it changes it to http://localhost/index.view Just so you know I clicked on Server address in the subsonic control panel. I even tried 127.0.0.1 and same thing. Also port 80 because its not being used. I even tried another port and same issue.
tegra
Postby tegra » Mon Aug 10, 2009 6:27 pm
Help
tegra
Postby tegra » Wed Aug 26, 2009 3:13 pm
Anyone ?
tegra
Postby datdamnzotz » Thu Oct 01, 2009 3:41 am
I was having the exact same error.
I am running Trend as antivirus on the box.
I had to turn av off, uninstall, reinstall to c:\subsonic and it works now.
Try disabling your AV, and see if that helps.
Worked for me
datdamnzotz
