Flash Woes!
Flash Woes!
Postby BurnUnit83 » Tue Aug 11, 2009 7:50 am
I am having a problem where flash does not work on any computer. It shows up, but when I try to play nothing happens. The flahs will tell me the correct length of song.
I've tried it on XP/7/Vista and Mac. It just does not want to use flash. It did at first, after indexing it stopped. I've done multiple uninstall and reinstalls.
The player shows up just doesn't do anything when you go to play. The buttons will allow you to go betweens songs.
Please halp! (Yes I mispelled that).
BurnUnit83
Postby BurnUnit83 » Wed Aug 12, 2009 4:08 am
Figured it out... Firefox error helped actually. I used Port 79... didn't realize this is used for finger requests... as luck would have it changing the port to one not in use that allowed firefox users to enter also fixed the flash problem.
All good now! Hope the solution helps others.
BurnUnit83
