Having trouble with LDAP in windows server 2k3
Postby steveblack » Mon Aug 24, 2009 9:37 pm
I have tried to use ldap and have failed. my credentials are right, i've tested a query on the sever without any issues, but when i configure subsonic to use it, it doesn't work. below is the output from the log file. Any ideas would be apreciated. -Steve-
[2009-08-24 17:19:52,437] INFO SubsonicLdapBindAuthenticator - Failed to authenticate user 'test' in LDAP.
org.acegisecurity.userdetails.UsernameNotFoundException: User Brendan not found in directory.
at org.acegisecurity.ldap.search.FilterBasedLdapUserSearch.searchForUser(FilterBasedLdapUserSearch.java:126)
at org.acegisecurity.providers.ldap.authenticator.BindAuthenticator.authenticate(BindAuthenticator.java:71)
at net.sourceforge.subsonic.ldap.SubsonicLdapBindAuthenticator.authenticate(SubsonicLdapBindAuthenticator.java:72)
at org.acegisecurity.providers.ldap.LdapAuthenticationProvider.retrieveUser(LdapAuthenticationProvider.java:233)
at org.acegisecurity.providers.dao.AbstractUserDetailsAuthenticationProvider.authenticate(AbstractUserDetailsAuthenticationProvider.java:119)
at org.acegisecurity.providers.ProviderManager.doAuthentication(ProviderManager.java:195)
at org.acegisecurity.AbstractAuthenticationManager.authenticate(AbstractAuthenticationManager.java:45)
at org.acegisecurity.ui.webapp.AuthenticationProcessingFilter.attemptAuthentication(AuthenticationProcessingFilter.java:71)
at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:252)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:844)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:644)
steveblack
Postby realtern » Mon Sep 28, 2009 8:23 am
Did you ever resolve this issue and if so, how?
realtern
Postby nickless » Sat Nov 21, 2009 11:07 pm
same Problem here:
query with credentials is OK, but Subsonic doesn't accept them.
DN and PW for LDAP bind is set correctly since anonymous binding is not working on Server 2008.
Settings:
LDAP URL: ldap://server.test.local:389/CN=Users,DC=test,DC=local
LDAP Search Filter: (sAMAccountName={0})
Log:
INFO SubsonicLdapBindAuthenticator - Failed to authenticate user 'testuser' in LDAP.
org.acegisecurity.userdetails.UsernameNotFoundException: User testuser not found in directory.
nickless
Postby nickless » Sun Nov 22, 2009 6:49 pm
got it!
changed "CN=Users" to "OU=Users"
nickless
