Change Title of page
Postby steveblack » Tue Aug 25, 2009 1:01 pm
Is there any way I can change the <Title> of the page
steveblack
Postby supra92 » Tue Aug 25, 2009 4:53 pm
Hey Steve -- you sure can!
I have the self-contained install on Linux (ie, the one that uses Jetty, not TOMCAT), so if you have this too then great. If not, you'll need to adjust the path where appropriate.
The file you need to edit is located here:
/var/subsonic/jetty/webapp/WEB_INF/jsp/head.jsp
If you're not using the standalone Subsonic one, then I suppose you'd look at:
$SUBSONIC_HOME/webapp/WEB_INF/jsp/head.jsp
So... in the head.jsp file, look at the very last line:
<title>Subsonic</title>
Just change that "Subsonic" to anything you desire. Since head.jsp is an INCLUDE file that is added to the beginning of every main JSP page, that title should follow for every page/link in the Subsonic app.
A bit longwinded I know, but hopefully that info helps. Let us know!
Cheers,
Supra92
supra92
Re: Change Title of page
Postby klm46 » Fri Dec 14, 2012 10:19 am
for me it was very helpful, thanks to you anyway ;)
klm46
Users browsing this forum: Google [Bot] and 19 guests
