Hostname Question
Hostname Question
Postby Joe_Archer » Sat Nov 25, 2006 1:26 pm
Hi, I've got subsonic working on my LAN (the application is fantastic by the way, many thanks)
However, I can only access the app by IP address, when I try to replace the IP with it's hostname in my browser, it fails.
eg. http://192.168.0.2:8180/subsonic - works fine
but
http://jukebox:8180/subsonic - does not I get: can't establish a connection to the server at jukebox:8180.
I can ping the machine by hostname, but for some reason cannot connect to subsonic using it. Is this a network issue or is there a configuration file I need to change to allow connection by hostname?
thanks,
Joe_Archer
Postby sindre_mehus » Sun Nov 26, 2006 8:43 am
That's most likely a network issue. There is no hostname-related configuration in Subsonic (or Tomcat, as far as I know).
Postby Joe_Archer » Thu Dec 07, 2006 5:34 pm
Thanks for the reply, it turned out to be a local DNS issue which is now fixed :D
Joe_Archer
Users browsing this forum: No registered users and 42 guests
