Randomization
Randomization
Postby RavienCoromana » Fri Aug 28, 2009 6:48 am
I dont know what hte problem is, but for some reason, neither me nor my streamers can use the random buttons for anything. The random under "more" dosent work, the random albums dosen't work... and random is what I live for... help?
RavienCoromana
Postby 3R3 » Fri Aug 28, 2009 8:05 am
have you changed anything, like adding a mod or something like that?
also, which version do you use?
and which installer did you use? (standalone, windows installer, linux)
and everything else is working and in order?
3R3
Postby RavienCoromana » Sat Aug 29, 2009 5:34 am
No, its just basic subsonic... I think I used the windows installer, v3.7
everything else works, just not the random... since I posted, I had it working for about 6 hours with the buttons, but then they dissappeared again... but this time, the random albums still works, and the random playlist works, but when you go into a folder, it shows the albums, but the "Play All | Play Random | Add All" Dosent show, neither does the play and add buttons next to each album, and when I go into songs, only the add button shows, not the play button.
RavienCoromana
Postby RavienCoromana » Sat Aug 29, 2009 6:02 am
Okay... that problem seems to only happen on the default Admin acct... I logged into one of my accts i made for my friends, and it works just fine... swapped back, still didnt work. any clue why admin would have LESS playability?
RavienCoromana
