Windows 7 RC (and full 7)
Postby tntornado » Tue Sep 01, 2009 11:35 pm
I'm having problems getting Subsonic to stay running in windows 7. When I start the computer it will run, but after while it will crash, and won't start back up without restarting the computer. I can get the tray Icon to come up, but the service itself won't.
Also, I can't change any options, it comes up with a blank error message.
Thanks for the help,
TnTornado
tntornado
Postby deriksen » Wed Sep 02, 2009 6:39 am
TnTornado,
You might want to check your services (from the start menu run/search services.msc). Check if the Subsonic Service has correct startup and recovery options. You might want to check you event viewer (from the start menu run/search compmgmt.msc) as well to see whether your OS has some post indicating what caused the service to stop/crash.
Just suggestions to help you start looking for causes. What build are you using? RC 7100?
/D
deriksen
Postby squipple » Fri Sep 04, 2009 7:04 pm
It's running fine on my Win7 Ultimate. Maybe it's a beta release issue?
squipple
