CAN'T INDEX MUSIC ON A NETWORK SHARE
Postby jomaweb » Thu Oct 01, 2009 6:36 pm
Hi all
I love this incredible piece of software, but since I moved my music folder to a NAS i'm unable to index and share the music.
I've tried different sintax for my shared folder.
/networkspace/MUSIC
smb:/networkspace/MUSIC
//networkspace/MUSIC
Subsonic installed and working under ubuntu Linux (before moving my music folder worked fine)
jomaweb
Postby jigsaw » Fri Oct 02, 2009 5:50 am
Hi jomaweb
Have you mounted the NAS using Samba from you Ubuntu-server? What is the path you use to access the share from say a terminal? It should work to put that in the share-folders settings in subsonic. I'm running server from Fedora 11 with all my media on a windows xp, just accessing through samba and works perfectly.
jigsaw
Postby jomaweb » Fri Oct 02, 2009 7:14 am
Yes, is Mounted using samba, and I can see in Nautilus the path to access the share as
jomaweb
Postby jigsaw » Fri Oct 02, 2009 11:19 pm
I think Nautilus might "help" you in accessing the samba-share. Could you find what path you would have to use to access the share from a terminal on the server? That path should be the only thing necessary to put in the configuration in Subsonic.
I have for instance mapped the d-drive on my windows host winxp to a folder, but all is done from /mnt and down - so I would type /mnt/winxp/d/music - which is access to the music-share.. Hope I'm not causing more confusion than help here :)
jigsaw
Mounts
Postby Aethies » Sat Oct 03, 2009 3:16 pm
jomaweb wrote:Yes, is Mounted using samba, and I can see in Nautilus the path to access the share as
Try mounting the nas share using smbmount from a command line, or just type:
mount -t cifs //nas/music /mnt/music
To auto-mount my shares, I use the following in the fstab ike this:
//nas/music /mnt/music cifs username=server_user,password=server_password,uid=1000,gid=users 0 0
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
2636.09 GB (10,769 hours)
Aethies
Postby jomaweb » Mon Oct 05, 2009 5:42 pm
mount -t cifs //nas/music /mnt/music gives me the following message:
Mounting the DFS root for a particular server not implemented yet
No ip address specified and hostname not found
jomaweb
Postby jigsaw » Mon Oct 05, 2009 5:57 pm
jomaweb wrote:mount -t cifs //nas/music /mnt/music gives me the following message:
Well in your case it's not //nas/music is it.. It's this one:
which then would be //networkspaces/MUSIC I guess.. Aethies was merely giving you the generic command to use. The last field /mnt/music is the folder to mount it to, change this also to what you wish.
jigsaw
Postby jomaweb » Mon Oct 05, 2009 6:59 pm
I got that point. I've modified the command to suit my particular case. Anyway no success
jomaweb
Postby jigsaw » Mon Oct 05, 2009 7:29 pm
My bad, no offense intended :)
However the error message "No ip address specified and hostname not found" implies that your computer does not recognize //networkspaces as host. What is the hostname or ip that you used in Nautilus to map up the drive? If it works with samba then it should also work with the mount command.
jigsaw
Postby jomaweb » Mon Oct 05, 2009 8:15 pm
No offended.
I don`t know how nautilus mounted the share but in Nautilus the path to access the folder is
jomaweb
Postby jigsaw » Tue Oct 06, 2009 5:08 am
Hmm.. Not too familiar with Nautilus, but this article ( http://www.redhat.com/docs/manuals/ente ... share.html ) suggests that in your case networkspace is actually a workgroup, is this correct?
In any case you could try to follow the tips here ( http://tldp.org/HOWTO/SMB-HOWTO-8.html ) and see if you cannot figure out what's the correct setup for you installation.
jigsaw
Postby jomaweb » Tue Oct 06, 2009 7:18 am
No. Networkspace is the machine Name, and MUSIC is the folder name.
jomaweb
Postby jigsaw » Tue Oct 06, 2009 6:29 pm
Did you try Aethies tip on fstab then? Followed by "mount -a"
Which OS are you on by the way?
jigsaw
Re: CAN'T INDEX MUSIC ON A NETWORK SHARE
Postby jomaweb » Tue Oct 06, 2009 7:45 pm
jomaweb wrote:Subsonic installed and working under ubuntu Linux (before moving my music folder worked fine)
tried fstab settings too.
Maybe it's impossible for linux to share a folder under samba not being the owner
jomaweb
Postby jigsaw » Tue Oct 06, 2009 8:41 pm
I'm running Subsonic on Fedora 11 with every single media file is on a external harddrive connected to my Windows XP and accessed as standard shared folder and samba client on the Fedora. Works like a charm. You need to make sure the folder is shared correctly from the windows-host and that you have the necessary things on the Linux server to mount it - e.g. samba client and cifs-driver. If you're not sure I seem to recall you can run "dmesg | tail" right after running the mount command and see if it says anything like "CIFS VFS: cifs_mount failed w/return code =".
jigsaw
