Bands that begin with "The"
Postby LeTsRiPiT » Tue Oct 06, 2009 9:51 pm
I just noticed that bands with a name that begins with "The" are being transported to the wrong position in the alphabet. A band like "The Kinks" is now being found in the "K" position of the alphabet. Why? Is there a setting that can return them to the correct position? Thanks in advance.
I'm running the new beta.
________
LeTsRiPiT
"The" names
Postby jeremyh » Tue Oct 06, 2009 10:45 pm
You can set which articles should be ignored (or not) under the Settings/General page. The option is "Articles to Ignore". Just remove 'The' from the list and you should be set.
jeremyh
Postby LeTsRiPiT » Tue Oct 06, 2009 11:20 pm
Thanks. Learning more each day!
________
LeTsRiPiT
