Can't stream over internet, local wireless works
Postby bawnzai » Tue Oct 13, 2009 3:09 am
Everything is setup as best I can tell. If I stream using my g1 phone using the subsonic client on my local network using wireless, it works just fine. When I connect through 3g I can connect and select which songs to play, but then as it tries to play it skips each song. The log messages are completely unhelpful.
I only have this problem on the linux client. If using the windows version of subsonic server, I can stream no problem over 3g. I know it's not tmobile breaking stuff.
I have transcoding set to no limit, so it should be disabled.
bawnzai
