Error Parsing Document on Android App
Postby MO » Sun Oct 18, 2009 11:47 am
I've got Subsonic successfully installed and operating on my local PC and can access the web interface via any browser, including on my G1 via 3G. However, when I try to access the server using the Subsonic Music Streaming app I get an error message saying:
"Connection Error. Error parsing document. (position: line - 1, column - 1,) caused by: org.apache.harmony.xml. ExpatParser$ParseException: At line 31, column 2: mismatched tag"
Any ideas?
MO
Postby sindre_mehus » Mon Oct 19, 2009 7:32 pm
That's most likely a configuration issue. Could you please answer the following:
o What version of the Subsonic server have you installed. You need 3.8.beta1 or later.
o Does the Android app work with the Subsonic Demo server?
o Do you get the same error using 3G and Wifi?
o What exactly have you specified in the server address field in the settings?
Cheers,
Postby MO » Tue Oct 20, 2009 9:46 am
Thanks Sindre!
I installed the 3.8beta1 version and am now able to successfully access my media using the Android app.
However, I can not play the media via the Android app (HTC Dream). I am able to view and download media via Subsonic, but when I try to play a song, it pulls the album art and gives me a notification that looks like the song is playing, but nothing actually happens. The same thing happens when I download a song, it pulls the album art and gives me a notification that looks like the song is playing, but nothing actually happens.
Maybe I have the the player settings in the server set up incorrectly?
I'm usually not this dense, I just really want this application to work for me! :oops:
MO
Postby hugodejong » Tue Oct 20, 2009 9:49 am
I get the same error as mentioned in the first post. My configuration is like this:
Subsonic 3.8b1
The App does work with the demo server (no problem at all)
Wifi or 3G doesn't make a difference
Address field: http://thuis.hugodejong.net
I use an HTC Hero with Android 1.5.
Whoops, installed 3.7 instead of 3.8b1, problem solved :)
hugodejong
