I can't even start Subsonic from the shell script...
Postby sickfish » Sun Oct 18, 2009 4:27 pm
Help! I've installed the standalone version as per instructions but when I try to start the standalone version, it claims to have started (displaying a PID) but when I try to connect... nothing.
Also - when I check the processes (ps -ef) the process doesn't exist.
The log has this in it:
61 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@25af00: display name [org.springframework.context.support.ClassPathXmlApplicationContext@25af00]; startup date [Sun Oct 18 17:20:24 GMT+01:00 2009]; root of context hierarchy
Exception in thread "main" java.lang.NoClassDefFoundError: org.springframework.core.CollectionFactory
at java.lang.Class.initializeClass(libgcj.so.81)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.<init>(DefaultSingletonBeanRegistry.java:86)
at org.springframework.beans.factory.support.AbstractBeanFactory.<init>(AbstractBeanFactory.java:152)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.<init>(AbstractAutowireCapableBeanFactory.java:143)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.<init>(AbstractAutowireCapableBeanFactory.java:154)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.<init>(DefaultListableBeanFactory.java:110)
at org.springframework.context.support.AbstractRefreshableApplicationContext.createBeanFactory(AbstractRefreshableApplicationContext.java:150)
at org.springframework.context.support.AbstractRefreshableApplicationContext.refreshBeanFactory(AbstractRefreshableApplicationContext.java:95)
at org.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory(AbstractApplicationContext.java:411)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:338)
at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:122)
at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:66)
at net.sourceforge.subsonic.booter.Main.<init>(Main.java:16)
at net.sourceforge.subsonic.booter.Main.main(Main.java:21)
Caused by: java.lang.ClassNotFoundException: edu.emory.mathcs.backport.java.util.concurrent.ConcurrentHashMap not found in gnu.gcj.runtime.SystemClassLoader{urls=[file:subsonic-booter-jar-with-dependencies.jar], parent=gnu.gcj.runtime.ExtensionClassLoader{urls=[], parent=null}}
at java.net.URLClassLoader.findClass(libgcj.so.81)
at gnu.gcj.runtime.SystemClassLoader.findClass(libgcj.so.81)
at java.lang.ClassLoader.loadClass(libgcj.so.81)
at java.lang.VMClassLoader.defineClass(libgcj.so.81)
at java.lang.ClassLoader.defineClass(libgcj.so.81)
at java.security.SecureClassLoader.defineClass(libgcj.so.81)
at java.lang.Class.forName(libgcj.so.81)
...13 more
sickfish
Postby Poffa » Sun Oct 18, 2009 6:36 pm
Poffa
Postby sickfish » Sun Oct 18, 2009 10:20 pm
Thanks very much! :D
That seems to have got it... once I selected Sun's Java as the default.
For any others that have this problem, I followed the instructions here to set the default Java installation :
https://help.ubuntu.com/community/Java
sickfish
