Problem with shortcuts
Postby dlmaldet » Sat Oct 24, 2009 12:32 am
I have Subsonic installed on a WHS server. My podcast files are saved at d:\shares\music\podcast. I'm not sure what to enter in the shortcut box to display the podcast shortcuts in the left hand panel.
dlmaldet
Re: Problem with shortcuts
Postby Aethies » Sat Oct 24, 2009 12:42 pm
dlmaldet wrote:I have Subsonic installed on a WHS server. My podcast files are saved at d:\shares\music\podcast. I'm not sure what to enter in the shortcut box to display the podcast shortcuts in the left hand panel.
If I am reading this right, you want to just display the podcasts that you have on the left hand pane?
Click on Settings | Music Folders and add that path there.
I am not sure what the filename is for podcasts, but you may have to go into Settings | General and add the extension of the podcast file to the music mask line in order for it to be displayed.
This should be what you are looking for.
Take care,
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
2636.09 GB (10,769 hours)
Aethies
Postby dlmaldet » Sat Oct 24, 2009 5:16 pm
I'll try to be more clear about my question. In the demo, there is a podcast heading on the left with a few podcast files listed under that. I was hoping to achieve the same thing and was thinking that I just had to get the proper entry under settings\general\shortcuts. If I'm correct, I'm not sure what to enter as the shortcut. If I'm wrong, I wonder what is necessary to have the same layout as the demo.
dlmaldet
Postby dlmaldet » Sat Oct 24, 2009 5:55 pm
I solved my problem. All shortcut folders need to be within the music folder for them to be recognized and displayed in the left panel.
dlmaldet
