Java Error with Version 3.8
Postby deejay2302 » Mon Oct 26, 2009 11:08 pm
I have an Errorfield on my Startsite. I have updated to 3.8 and comes Error. What can i do ?
Here is the Error:
Exception java.lang.OutOfMemoryError
Message Java heap space
Java version Sun Microsystems Inc. 1.6.0_16
Operating system Windows XP 5.1
Server jetty-6.1.x
Memory Used 63 of 63 MB
Stack trace java.lang.OutOfMemoryError: Java heap space at org.apache.xerces.dom.DeferredDocumentImpl.getNodeObject(Unknown Source) at org.apache.xerces.dom.DeferredDocumentImpl.synchronizeChildren(Unknown Source) at org.apache.xerces.dom.DeferredElementNSImpl.synchronizeChildren(Unknown Source) at org.apache.xerces.dom.ParentNode.getChildNodes(Unknown Source) at org.apache.jasper.xmlparser.ParserUtils.convert(ParserUtils.java:163) at org.apache.jasper.xmlparser.ParserUtils.convert(ParserUtils.java:178) at org.apache.jasper.xmlparser.ParserUtils.convert(ParserUtils.java:178) at org.apache.jasper.xmlparser.ParserUtils.parseXMLDocument(ParserUtils.java:115) at org.apache.jasper.xmlparser.ParserUtils.parseXMLDocument(ParserUtils.java:132) at org.apache.jasper.compiler.TldLocationsCache.getUriFromTld(TldLocationsCache.java:465) at org.apache.jasper.compiler.TldLocationsCache.scanJar(TldLocationsCache.java:372) at org.apache.jasper.compiler.TldLocationsCache.scanJars(TldLocationsCache.java:517) at org.apache.jasper.compiler.TldLocationsCache.init(TldLocationsCache.java:249) at org.apache.jasper.compiler.TldLocationsCache.getLocation(TldLocationsCache.java:224) at org.apache.jasper.JspCompilationContext.getTldLocation(JspCompilationContext.java:526) at org.apache.jasper.compiler.Parser.parseTaglibDirective(Parser.java:422) at org.apache.jasper.compiler.Parser.parseDirective(Parser.java:492) at org.apache.jasper.compiler.Parser.parseElements(Parser.java:1552) at org.apache.jasper.compiler.Parser.parse(Parser.java:126) at org.apache.jasper.compiler.ParserController.doParse(ParserController.java:211) at org.apache.jasper.compiler.ParserController.parse(ParserController.java:116) at org.apache.jasper.compiler.Parser.processIncludeDirective(Parser.java:335) at org.apache.jasper.compiler.Parser.parseIncludeDirective(Parser.java:372) at org.apache.jasper.compiler.Parser.parseDirective(Parser.java:484) at org.apache.jasper.compiler.Parser.parseElements(Parser.java:1552) at org.apache.jasper.compiler.Parser.parse(Parser.java:126) at org.apache.jasper.compiler.ParserController.doParse(ParserController.java:211) at org.apache.jasper.compiler.ParserController.parse(ParserController.java:116) at org.apache.jasper.compiler.Parser.processIncludeDirective(Parser.java:335) at org.apache.jasper.compiler.Parser.parseIncludeDirective(Parser.java:372) at org.apache.jasper.compiler.Parser.parseDirective(Parser.java:484) at org.apache.jasper.compiler.Parser.parseElements(Parser.java:1552)
21.681 Artists
58.141 Albums
674.091 Songs
5072,14 GB (~ 49.341 Hours)
deejay2302
Postby jigsaw » Mon Oct 26, 2009 11:26 pm
Hi deejay,
Try increasing the allocated memory for Subsonic from 64MB to say 128MB. On Windows I believe this is done via the settings on the tray-icon.
jigsaw
Postby deejay2302 » Tue Oct 27, 2009 3:27 pm
More Not ? Sure?
I have reinstalled the older Version (Beta 1). :-/ The Beta works with 64mb. Why not the Full release ? This is a mystery to me.^^
21.681 Artists
58.141 Albums
674.091 Songs
deejay2302
Postby deejay2302 » Thu Oct 29, 2009 12:11 am
Ok it works. Your tip was right! Great THX ;)
21.681 Artists
58.141 Albums
674.091 Songs
deejay2302
