Who's playing what? Custom Themes
Postby streamme » Wed Oct 28, 2009 4:23 pm
I was curious to know if there's any way to get Subsonic 3.8 to show what each connected user is currently playing. Can we do that, at all?
Also how can one create custom themes to go with Susbsonic. Is that at all possible?
I just recently discovered Subsonic 3.7 and now 3.8 is out and it's amazing. I only stream on my local network and it's amazing, so great work.
Thanks in advance.
streamme
Postby jigsaw » Wed Oct 28, 2009 5:47 pm
Hi streamme
The "Now playing" feature already exists. Check that your personal settings have the "Show what others are playing" option enabled and go to the "Home" tab. You'll see it in the right-pane frame.
Yes you can create custom themes. There's no tutorial of this though, so I guess you would need to sneak a peak on the existing themes and work your way from there.
-jigsaw
jigsaw
