Mac OS X 10.6.x startup help
Postby jeffpetersen » Sat Nov 07, 2009 10:18 pm
Hi everybody,
I have just replaced an old P4 that was running Subsonic with a new Mac Mini. I have managed to get Subsonic installed, and it starts fine when I run the shell script in the subsonic folder.
I want Subsonic to launch at startup, and I have been searching the forum for days, but can't find any method that works. Google tells me that I should be able to use launchd to execute a script at start, but that is about as far as I got with that.
Any advice would be greatly appreciated!
jeffpetersen
Try Applescript
Postby pabney » Mon Nov 09, 2009 5:03 pm
I had the same problem. I solved it by creating a one line applescript, saving as an app, and putting it in my account startups.
Here is the line I use, you will have to change the path accordingly.
do shell script "users/prepress/music/subsonic/subsonic.sh"
Let me know if you need more info.
Paul
pabney
Postby jeffpetersen » Mon Nov 09, 2009 5:09 pm
Thanks! I'll give it a try when I get home this evening.
jeffpetersen
Postby jeffpetersen » Tue Nov 10, 2009 1:42 am
Perfect, and so simple! Thanks for your help.
jeffpetersen
