Large Playlist with Android Device
Postby mluhring » Sun Nov 15, 2009 6:21 pm
I created a playlist with about 1500 songs. I am running the subsonic app on an Motorola Droid. When I select the playlist I get an operation timeout error. Is there a size limit on playlists? This list itself is only 115K. Are there any settings I can set to increase the timeout?
I made a playlist with about half the songs and I can get that playlist to load. Below is info from the log file. Ii don't know if the access denied is on the playlist file or a file referenced in the playlist.
Here is what is in the log file:
[2009-11-15 12:56:41,338] WARN PlaylistService - Access denied to file
java.lang.SecurityException: Access denied to file
at net.sourceforge.subsonic.service.MusicFileService.getMusicFile(MusicFileService.java:69)
at net.sourceforge.subsonic.service.PlaylistService$M3UFormat.loadPlaylist(PlaylistService.java:216)
at net.sourceforge.subsonic.service.PlaylistService.loadPlaylist(PlaylistService.java:100)
at net.sourceforge.subsonic.controller.RESTController.getPlaylist(RESTController.java:293)
at sun.reflect.GeneratedMethodAccessor373.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:473)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:410)
at net.sourceforge.subsonic.security.RESTRequestParameterProcessingFilter.doFilter(RESTRequestParameterProcessingFilter.java:108)
mluhring
Postby SabreCEO » Sun Nov 15, 2009 7:38 pm
Right now you're probably better off it's not working. With the new release for Android, all songs in a playlist are downloaded instead of being streamed on a per song basis. So if you have 1500 songs in a playlist, the app will download constantly while you're listening to music - so after and hour or two you may have downloaded over 5 GIGAbytes of data!
Several people have suggested that the app let you limit how many songs in advance on your playlist are downloaded in advance (I'd probably set mine to 1 song). As well as the ability to limit the size of the cache, or automatically delete the cache periodically.
Until then unfortunately you should probably limit your playlists to no more than 20 or so songs, because of the amount of data you will be downloading...
-Mark
SabreCEO
