Android Connection Problems
Postby jeremyh » Fri Nov 20, 2009 7:16 pm
We have our server running on port 8180 (with a redirect from port 80) and I can't seem to connect with the Android app.
If I launch the Android subsonic app, and put in the address with and without the port, the "test conection" button returns "Connection failure. Resource not found".
(For server I am putting http://x.x.x.x:8180 or http://x.x.x.x, where x.x.x.x is the IP)
I also tried connecting with the built in browser and it gives me "web page not available" - even though I seem to be able to ping the address (from the free PING application).
The phone is a Motorola Cliq running Android 1.5.
jeremyh
Postby kdid » Tue Nov 24, 2009 9:19 am
Have you tried to temporary use the standard port 80 to verify that it is working with the Android app.?
Maybe some ports is blocked by your ISP.
-- kdid
kdid
Postby jeremyh » Wed Nov 25, 2009 3:30 pm
Well, the site is not exposed through the internet. I was trying to connect to an instance that is used internally to our network. I was connecting my phone via WiFi to the network and expecting it to see the local resources (which are behind a firewall to the internet). It doesn't seem like the app can see the local resources (yet I can ping both directions).
jeremyh
