Windows is fine, but not working under Ubuntu 9.1/'Tomcat6
Postby deputyjones » Mon Dec 14, 2009 1:25 pm
Hi all and thanks to the developers for great software. I installed it under Ubuntu and although Tomcat seems to be working fine (I get the "It Works!" message @ http://localhost:8080) I get a 404 error when going to http://localhost:8080/subsonic
I installed it under Windows 7 on another machine and that works fine. I also tried the fix for Tomcat6 suggested in another thread by turning security off. Still no worky.
Below is subsonic_sh.log from when I fired up the serving this morning. There does not seem to be any errors, but thought it might be useful. TIA!
103 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@1632c2d: display name [org.springframework.context.support.ClassPathXmlApplicationContext@1632c2d]; startup date [Mon Dec 14 08:14:05 EST 2009]; root of context hierarchy
357 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
1714 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@1632c2d]: org.springframework.beans.factory.support.DefaultListableBeanFactory@55e55f
1780 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@55e55f: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
1898 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
Using WAR file: /var/subsonic/standalone/subsonic.war
Extracting webapp to /var/subsonic/jetty/1130
2091 [main] INFO org.mortbay.log - jetty-6.1.x
4583 [main] INFO / - Initializing Spring root WebApplicationContext
4583 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization started
4722 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@6d0040: display name [Root WebApplicationContext]; startup date [Mon Dec 14 08:14:10 EST 2009]; root of context hierarchy
4925 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-service.xml]
5414 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-security.xml]
5780 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-cache.xml]
6060 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@6d0040]: org.springframework.beans.factory.support.DefaultListableBeanFactory@a00185
6521 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@a00185: defining beans [playerDao,internetRadioDao,musicFileInfoDao,musicFolderDao,userDao,transcodingDao,podcastDao,avatarDao,daoHelper,musicFileService,securityService,settingsService,searchService,playerService,playlistService,versionService,statusService,musicInfoService,musicIndexService,amazonSearchService,discogsSearchService,audioScrobblerService,transcodingService,podcastService,adService,jukeboxService,ajaxNowPlayingService,ajaxPlaylistService,ajaxLyricsService,ajaxCoverArtService,ajaxTagService,ajaxTransferService,ajaxChatService,filterChainProxy,httpSessionContextIntegrationFilter,logoutFilter,authenticationProcessingFilter,basicProcessingFilter,mobileRequestParameterProcessingFilter,restRequestParameterProcessingFilter,basicProcessingFilterEntryPoint,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,exceptionTranslationFilter,basicExceptionTranslationFilter,filterInvocationInterceptor,accessDecisionManager,rememberMeServices,authenticationManager,daoAuthenticationProvider,userCacheWrapper,ldapAuthenticationProvider,bindAuthenticator,userDetailsServiceBasedAuthoritiesPopulator,ajaxServiceInterceptor,ajaxTagServiceSecure,ajaxTransferServiceSecure,cacheManager,userCache,musicFileCache,childDirCache,coverArtCache,musicFolderCache,chatCache]; root of factory hierarchy
6732 [main] INFO org.springframework.jdbc.datasource.DriverManagerDataSource - Loaded JDBC driver: org.hsqldb.jdbcDriver
8921 [main] INFO org.springframework.cache.ehcache.EhCacheManagerFactoryBean - Initializing EHCache CacheManager
Dec 14, 2009 8:14:14 AM net.sf.ehcache.CacheManager addShutdownHookIfRequired
INFO: The CacheManager shutdown hook is enabled because net.sf.ehcache.enableShutdownHook is set to true.
Dec 14, 2009 8:14:14 AM net.sf.ehcache.Cache initialise
WARNING: Cache: musicFolderCache has a maxElementsInMemory of 0. It is strongly recommended to have a maximumSize of at least 1. Performance is halved by not using a MemoryStore.
WARNING: Cache: chatCache has a maxElementsInMemory of 0. It is strongly recommended to have a maximumSize of at least 1. Performance is halved by not using a MemoryStore.
9951 [main] INFO org.acegisecurity.intercept.AbstractSecurityInterceptor - Validated configuration attributes
9983 [main] INFO org.acegisecurity.intercept.method.MethodDefinitionMap - Adding secure method [public net.sourceforge.subsonic.ajax.UploadInfo net.sourceforge.subsonic.ajax.TransferService.getUploadInfo()] with attributes [[ROLE_UPLOAD]]
9984 [main] INFO org.acegisecurity.intercept.method.MethodDefinitionMap - Adding secure method [public java.lang.String net.sourceforge.subsonic.ajax.TagService.setTags(java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String)] with attributes [[ROLE_COVERART]]
9985 [main] INFO org.acegisecurity.intercept.AbstractSecurityInterceptor - Validated configuration attributes
10076 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization completed in 5493 ms
10301 [main] INFO / - Initializing Spring FrameworkServlet 'subsonic'
10301 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization started
10304 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@156e5ed: display name [WebApplicationContext for namespace 'subsonic-servlet']; startup date [Mon Dec 14 08:14:15 EST 2009]; parent: org.springframework.web.context.support.XmlWebApplicationContext@6d0040
10305 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/subsonic-servlet.xml]
10839 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@156e5ed]: org.springframework.beans.factory.support.DefaultListableBeanFactory@c8c7d6
11218 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@c8c7d6: defining beans [leftController,rightController,statusController,mainController,topController,helpController,moreController,uploadController,lyricsController,allmusicController,podcastController,podcastReceiverController,podcastReceiverAdminController,setMusicFileInfoController,setRatingController,albumInfoController,randomPlaylistController,loadPlaylistController,savePlaylistController,changeCoverArtController,nowPlayingController,searchController,settingsController,playerSettingsController,musicFolderSettingsController,transcodingSettingsController,internetRadioSettingsController,podcastSettingsController,searchSettingsController,generalSettingsController,advancedSettingsController,personalSettingsController,avatarUploadController,userSettingsController,passwordSettingsController,homeController,editTagsController,playlistController,xspfPlaylistController,coverArtController,avatarController,proxyController,statusChartController,userChartController,m3uController,streamController,downloadController,donateController,multiController,wapController,mobileController,restController,dbController,savePlaylistValidator,donateValidator,userSettingsValidator,passwordSettingsValidator,urlMapping,messageSource,themeSource,localeResolver,themeResolver,viewResolver]; parent: org.springframework.beans.factory.support.DefaultListableBeanFactory@a00185
13684 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization completed in 3383 ms
13911 [main] WARN org.mortbay.log - failed SelectChannelConnector@0.0.0.0:8080
java.net.BindException: Address already in use
at sun.nio.ch.Net.bind(Native Method)
at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:137)
at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:77)
at org.mortbay.jetty.nio.SelectChannelConnector.open(SelectChannelConnector.java:211)
at org.mortbay.jetty.nio.SelectChannelConnector.doStart(SelectChannelConnector.java:309)
at org.mortbay.jetty.Server.doStart(Server.java:228)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:99)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:57)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:532)
at net.sourceforge.subsonic.booter.Main.<init>(Main.java:16)
at net.sourceforge.subsonic.booter.Main.main(Main.java:21)
13915 [main] WARN org.mortbay.log - failed Server@3650ed
14204 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
14389 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
14531 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[127.0.1.1:9412](local),objID:[0:0:0, 0]]]]
deputyjones
Postby deputyjones » Mon Dec 14, 2009 4:08 pm
I followed the instructions here:
http://forum.subsonic.org/forum/viewtopic.php?t=1486
However, I wonder if:
#1. The subsonic files need to installed somewhere else to be found by Tomcat?
#2. Or if Tomcat itself needs to be configured somehow?
deputyjones
Postby jigsaw » Thu Dec 17, 2009 6:23 pm
Hi deputyjones,
Did you catch this part:
Looks like perhaps you already have something else running which is occupying port 8080.
Try something like this:
$ sudo netstat -tap | grep LISTEN | grep 8080
jigsaw
