SocketTimeoutException
Postby Jips » Wed Dec 16, 2009 10:16 pm
Hi
I use Subsonic under Windows XP SP3 and the android application.
I use my public IP adress on port 8080 as server adress. The port forwarding is correctly configured on my router.
When I stream a song on my phone from the LAN connection, I have no problem to listen to music. But from the 3G connection I get the following error :
Error downloading"[Song Name]".
The operation timed out (SocketTimeoutExeption").
What am I doing wrong ?
Thanls for your help.
Jips
Postby jigsaw » Thu Dec 17, 2009 6:32 pm
Have you verified that the subsonic server is accessible from outside your LAN? You can test it by simply using a browser from anywhere else than inside you home network and access the web-interface..
If you cannot access it from a browser either, then you at least know that it has nothing to do with your Android.
jigsaw
Postby Jips » Fri Dec 18, 2009 12:19 pm
Hi
I just tried from another computer on another network and it worked perfectly (web application and music streaming).
I will try the android client on the same network (not 3G but WIFI) and see if it's a problem from my 3G access provider.
Jips
