Subsonic not connectable under Windows 7
Postby deejay2302 » Thu Dec 17, 2009 11:05 am
I have a problem with Windows 7. My server now runs under Windows 7 Only the server is not reachable.
I normally use port 8080 But when I in the control panel on port 8080 terminates Subsonic does not change the port.
The address remains despite its http / / localhost /,
and not as it was before http / / localhost: 8080 /.
Save Settings and Restart Services does not help. He does not change the setting. I'm using a recent Java and a 200MB memory limit, I use. There is no error and also the firewall and router are configured correctly.
Why might that be? And where I could manually change it?
21.681 Artists
58.141 Albums
674.091 Songs
5072,14 GB (~ 49.341 Hours)
deejay2302
Postby deejay2302 » Fri Dec 25, 2009 5:02 am
Problem Solved!
Was the false install path.
False: C:/Programs/Subsonic
Right: C:/Program Files x86/Subsonic
And it works ;)
21.681 Artists
58.141 Albums
674.091 Songs
deejay2302
