Music changes pitch within a song as song plays.
Postby PaulyWolly » Wed Dec 30, 2009 3:49 pm
First I want to say - NICE System. I have been trying to find a system to set up my own podcasts and stream my own music for some time now and SUBSONIC is great.
I am having an annoying problem though - my music changes pitch within a song as a song plays.
Is there maybe somewhere I can make a change to the buffer or something, to correct this? It sounds like I am playing an CD and placing my finger on and off the disc to slow it down as it is playing - normal to slow then back to normal pitch.
PaulyWolly
Postby Piker9 » Wed Dec 30, 2009 3:56 pm
I know nothing about subsonic but the first thing that comes to my mind is what file format is your music, and what bit rate? Have you tried transcoding to a lower bit rate?
Piker9
MP3 format. Not sure what you mean about 'transcoding'
Postby PaulyWolly » Wed Dec 30, 2009 4:37 pm
My songs are MP3 format. I do not knwo what you mean about transcoding. Is this something I can do through Subsonic? or can I re-code the MP3s?
PaulyWolly
Postby Piker9 » Wed Dec 30, 2009 9:09 pm
Yes, transcoding to a slower bit rate might help if you are having bandwith problems. But it seems strange that a bandwith problem would manifest itself by changing the pitch of your songs...so maybe that's not your problem. Usually when I have that problem the song breaks up and don't play completely.
Piker9
Postby PaulyWolly » Thu Dec 31, 2009 1:27 am
Now I am having issues where the song stops then restarts. It is very annoying. I cannot hear a song all the way through without it stopping then restarting.
PaulyWolly
Postby PaulyWolly » Sat Jan 02, 2010 9:10 pm
After reviewing re-creating a transcoding to remove the VBR setting from another post I was able to remove ALOT of the issue where songs are restarting and skipping to the point where I can at least listen to a song.
Every song playing stops and skips at 17 seconds, then I am still getting the PITCH changing in the song. It is almost as if the song starts at a higher pitch, then at 17 seconds it restarts then the pitch goes down and stays at like 80% of songs normal pitch. :?
PaulyWolly
Postby Xarias » Mon Jan 18, 2010 5:34 pm
I've had weird things like this myself.
I had an album I listened to often that suddenly each song was showing up as twice the time, for example, a three minute song would show up as a six minutes and each song had that much time of silence after it actually ended.
I've also had files that Subsonic plays, but thinks the file ends at a certain point, (where it really doesn't), and stops the song at that location.
I'd love to know what that's about.
Xarias
