SIGSEGV in ld-linux.so.2 when starting playing - Solved
Postby migu » Thu Jan 07, 2010 3:26 pm
I had the most annoying bug bother me ever since I installed subsonic on my linux server, I could not initiate a song. Every time I tried the GUI went dead with a long segmentation fault log as a result (the java process died as well). I was about to give up when i found a similar bug report on a ruby forum (here) that stated an error in libc6-i686 on Ubuntu 8.10 with similar results, the proposed solution did not work, but at least it gave me some pointers as to what might be wrong.
Anyways, with a long overdue upgrade in mind i went to work and upgraded my dist to 9.10 and now playing music works like a charm :)
I realize that this was a very hard core way of solving the problem, but it works now, and that is fine by me. I thought these lines might help someone else in the same predicament.
Just in case, I'll post the log below:
---------------------SNIP----------------------
# An unexpected error has been detected by Java Runtime Environment:
# SIGSEGV (0xb) at pc=0xb7f7efed, pid=9854, tid=3026733968
# Java VM: OpenJDK Client VM (1.6.0_0-b12 mixed mode, sharing linux-x86)
# Distribution: Ubuntu 8.10, package 6b12-0ubuntu6.6
# Problematic frame:
# C [ld-linux.so.2+0x12fed]
# If you would like to submit a bug report, please include
# instructions how to reproduce the bug and visit:
# https://bugs.launchpad.net/ubuntu/+source/openjdk-6/
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x08cb1c00): JavaThread "btpool0-6" [_thread_in_native, id=9889, stack(0xb4635000,0xb4685000)]
siginfo:si_signo=SIGSEGV: si_errno=0, si_code=1 (SEGV_MAPERR), si_addr=0x00000200
Registers:
EAX=0xb7f87cc0, EBX=0xb7f87ff4, ECX=0xb7f796f9, EDX=0xb4684b8c
ESP=0xb4682680, EBP=0xb46826a8, ESI=0x00000000, EDI=0x00000000
EIP=0xb7f7efed, CR2=0x00000200, EFLAGS=0x00010292
Top of Stack: (sp=0xb4682680)
0xb4682680: 08ae4cf0 b4682770 b7f752af b4682760
0xb4682690: b44bd3e4 b4682754 b7f887c4 b7f2fff4
0xb46826a0: 00000000 08cb0958 b46826b8 b7f2dc94
0xb46826b0: 00000000 b7f87ff4 b4682798 b7f79716
0xb46826c0: 00000000 00000000 b4682760 b4682754
0xb46826d0: 08cb0960 08cb0968 08cb0964 b4684b8c
0xb46826e0: 08ae4b38 b44bd777 00000000 00000000
0xb46826f0: b7f87ff4 b7f87cc0 08cb0958 b4682798
Instructions: (pc=0xb7f7efed)
0xb7f7efdd: 5d f4 89 75 f8 e8 d4 2d 00 00 81 c3 0d 90 00 00
0xb7f7efed: f6 87 00 02 00 00 08 75 37 8b 97 90 01 00 00 85
Stack: [0xb4635000,0xb4685000], sp=0xb4682680, free space=309k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [libdl.so.2+0xc94]
C [ld-linux.so.2+0xd716]
C [libdl.so.2+0x10ac]
C [libdl.so.2+0xcca] dlclose+0x2a
C [libjpeg.so+0x1cb0]
C [libjpeg.so+0x1fdf] Java_com_sun_imageio_plugins_jpeg_JPEGImageReader_initReaderIDs+0x1f
v ~BufferBlob::Interpreter
v ~BufferBlob::StubRoutines (1)
V [libjvm.so+0x194c27]
V [libjvm.so+0x26db89]
V [libjvm.so+0x193eff]
V [libjvm.so+0x16fd86]
V [libjvm.so+0x16fdf1]
V [libjvm.so+0x170d35]
V [libjvm.so+0x171268]
V [libjvm.so+0x187e6d]
---SNIP--- and so it continues for a screenfull ---
J org.mortbay.jetty.HttpParser.parseNext()J
V [libjvm.so+0x1943d2]
V [libjvm.so+0x19455a]
V [libjvm.so+0x1e5006]
V [libjvm.so+0x2fdbac]
V [libjvm.so+0x2fdc6a]
V [libjvm.so+0x2732d9]
C [libpthread.so.0+0x5fc0]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
---SNIP--- and so it continues for a screenfull (again)---
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x089df400 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=9891, stack(0xb46ff000,0xb474f000)]
0x08cc3800 JavaThread "Timer-2" [_thread_blocked, id=9890, stack(0xb45c6000,0xb4616000)]
=>0x08cb1c00 JavaThread "btpool0-6" [_thread_in_native, id=9889, stack(0xb4635000,0xb4685000)]
0x08c17800 JavaThread "btpool0-5" [_thread_blocked, id=9888, stack(0xb46af000,0xb46ff000)]
0x08b91c00 JavaThread "btpool0-4" [_thread_blocked, id=9886, stack(0xb4776000,0xb47c6000)]
0x08817000 JavaThread "btpool0-3" [_thread_blocked, id=9881, stack(0xb47c6000,0xb4816000)]
0x08788800 JavaThread "DestroyJavaVM" [_thread_blocked, id=9855, stack(0xb75b8000,0xb7608000)]
0x08807c00 JavaThread "GC Daemon" daemon [_thread_blocked, id=9878, stack(0xb4816000,0xb4866000)]
0x08806c00 JavaThread "RMI Reaper" [_thread_blocked, id=9877, stack(0xb4866000,0xb48b6000)]
0x089e8000 JavaThread "RMI TCP Accept-0" daemon [_thread_in_native, id=9876, stack(0xb48b6000,0xb4906000)]
0x089d0400 JavaThread "RMI TCP Accept-9412" daemon [_thread_in_native, id=9875, stack(0xb4906000,0xb4956000)]
0x08aa7800 JavaThread "pool-2-thread-1" [_thread_blocked, id=9874, stack(0xb4956000,0xb49a6000)]
0x08aa1000 JavaThread "pool-1-thread-1" daemon [_thread_blocked, id=9873, stack(0xb49a6000,0xb49f6000)]
0x08a84000 JavaThread "Timer-1" daemon [_thread_blocked, id=9872, stack(0xb49f6000,0xb4a46000)]
0x08a8ec00 JavaThread "Store chatCache Spool Thread" daemon [_thread_blocked, id=9871, stack(0xb4a46000,0xb4a96000)]
0x08a86000 JavaThread "Store musicFolderCache Spool Thread" daemon [_thread_blocked, id=9870, stack(0xb4a96000,0xb4ae6000)]
0x08974800 JavaThread "HSQLDB Timer @2f0d54" daemon [_thread_blocked, id=9869, stack(0xb4bea000,0xb4c3a000)]
0x08914800 JavaThread "Timer-0" [_thread_blocked, id=9868, stack(0xb4c43000,0xb4c93000)]
0x088f2c00 JavaThread "btpool0-0 - Acceptor0 SelectChannelConnector@0.0.0.0:8081" [_thread_in_native, id=9863, stack(0xb4dbd000,0xb4e0d000)]
0x087cf800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=9861, stack(0xb4fe6000,0xb5036000)]
0x087c4c00 JavaThread "CompilerThread0" daemon [_thread_blocked, id=9860, stack(0xb5036000,0xb50b6000)]
0x087c3400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=9859, stack(0xb50b6000,0xb5106000)]
0x087bd800 JavaThread "Finalizer" daemon [_thread_blocked, id=9858, stack(0xb514c000,0xb519c000)]
0x087b9400 JavaThread "Reference Handler" daemon [_thread_blocked, id=9857, stack(0xb519c000,0xb51ec000)]
Other Threads:
0x087b7c00 VMThread [stack: 0xb51ec000,0xb526c000] [id=9856]
0x087d0c00 WatcherThread [stack: 0xb4f66000,0xb4fe6000] [id=9862]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 960K, used 376K [0x8d910000, 0x8da10000, 0x8db80000)
eden space 896K, 39% used [0x8d910000, 0x8d968978, 0x8d9f0000)
from space 64K, 34% used [0x8da00000, 0x8da05840, 0x8da10000)
to space 64K, 0% used [0x8d9f0000, 0x8d9f0000, 0x8da00000)
tenured generation total 9144K, used 8721K [0x8db80000, 0x8e46e000, 0x8f910000)
the space 9144K, 95% used [0x8db80000, 0x8e4047e0, 0x8e404800, 0x8e46e000)
compacting perm gen total 14592K, used 14343K [0x8f910000, 0x90750000, 0x93910000)
the space 14592K, 98% used [0x8f910000, 0x90711d78, 0x90711e00, 0x90750000)
ro space 8192K, 89% used [0x93910000, 0x9403c530, 0x9403c600, 0x94110000)
rw space 12288K, 59% used [0x94110000, 0x94839500, 0x94839600, 0x94d10000)
Dynamic libraries:
08048000-08051000 r-xp 00000000 08:01 3267 /usr/lib/jvm/java-6-openjdk/jre/bin/java
08051000-08052000 r--p 00008000 08:01 3267 /usr/lib/jvm/java-6-openjdk/jre/bin/java
08052000-08053000 rw-p 00009000 08:01 3267 /usr/lib/jvm/java-6-openjdk/jre/bin/java
08782000-08ddc000 rw-p 08782000 00:00 0 [heap]
8d910000-8da10000 rwxp 8d910000 00:00 0
8da10000-8db80000 rwxp 8da10000 00:00 0
8db80000-8e46e000 rwxp 8db80000 00:00 0
8e46e000-8f910000 rwxp 8e46e000 00:00 0
8f910000-90750000 rwxp 8f910000 00:00 0
90750000-93910000 rwxp 90750000 00:00 0
93910000-9403d000 r--s 00001000 08:01 3305 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/client/classes.jsa
9403d000-94110000 rwxp 9403d000 00:00 0
94110000-9483a000 rw-p 0072e000 08:01 3305 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/client/classes.jsa
9483a000-94d10000 rwxp 9483a000 00:00 0
94d10000-94e07000 rw-p 00e58000 08:01 3305 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/client/classes.jsa
94e07000-95110000 rwxp 94e07000 00:00 0
95110000-95114000 r-xs 00f4f000 08:01 3305 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/client/classes.jsa
95114000-95510000 rwxp 95114000 00:00 0
b44bd000-b44c6000 r-xp 00000000 08:01 3221 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libjpeg.so
b44c6000-b44c7000 r--p 00008000 08:01 3221 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libjpeg.so
b44c7000-b44c8000 rw-p 00009000 08:01 3221 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libjpeg.so
b44c8000-b44f4000 r-xp 00000000 08:01 3224 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/liblcms.so
b44f4000-b44f5000 r--p 0002b000 08:01 3224 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/liblcms.so
b44f5000-b44f6000 rw-p 0002c000 08:01 3224 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/liblcms.so
b44f6000-b44f9000 rw-p b44f6000 00:00 0
b44f9000-b44fd000 r-xp 00000000 08:01 3204 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/headless/libmawt.so
b44fd000-b44fe000 r--p 00004000 08:01 3204 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/headless/libmawt.so
b44fe000-b44ff000 rw-p 00005000 08:01 3204 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/headless/libmawt.so
b44ff000-b4583000 r-xp 00000000 08:01 3208 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libawt.so
b4583000-b4584000 r--p 00083000 08:01 3208 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libawt.so
b4584000-b458a000 rw-p 00084000 08:01 3208 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libawt.so
b458a000-b45af000 rw-p b458a000 00:00 0
b45af000-b45bc000 r--s 00000000 08:08 65591 /var/subsonic/jetty/1130/webapp/flash/jw-player-4.4.swf
b45bc000-b45bd000 r--s 00000000 08:08 65633 /var/subsonic/jetty/1130/webapp/icons/current.gif
b45bd000-b45be000 r--s 00000000 08:08 65636 /var/subsonic/jetty/1130/webapp/icons/down.gif
b45be000-b45bf000 r--s 00000000 08:08 65700 /var/subsonic/jetty/1130/webapp/icons/remove.gif
b45bf000-b45c0000 r--s 00000000 08:08 65800 /var/subsonic/jetty/1130/webapp/script/webfx/luna.css
b45c0000-b45c4000 r--s 00000000 08:08 65802 /var/subsonic/jetty/1130/webapp/script/webfx/slider.js
b45c4000-b45c5000 r--s 00000000 08:08 65803 /var/subsonic/jetty/1130/webapp/script/webfx/timer.js
b45c5000-b45c6000 r--s 00000000 08:08 65754 /var/subsonic/jetty/1130/webapp/script/fancyzoom/images/zoom-caption-fill.png
b45c6000-b45c9000 ---p b45c6000 00:00 0
b45c9000-b4616000 rwxp b45c9000 00:00 0
b4616000-b4617000 r--s 00000000 08:08 65756 /var/subsonic/jetty/1130/webapp/script/fancyzoom/images/zoom-caption-r.png
b4617000-b4618000 r--s 00000000 08:08 65755 /var/subsonic/jetty/1130/webapp/script/fancyzoom/images/zoom-caption-l.png
b4618000-b4619000 r--s 00000000 08:08 65752 /var/subsonic/jetty/1130/webapp/script/fancyzoom/images/closebox.png
b4619000-b461a000 r--s 00000000 08:08 65753 /var/subsonic/jetty/1130/webapp/script/fancyzoom/images/spacer.gif
b461a000-b461b000 r--s 00000000 08:08 65765 /var/subsonic/jetty/1130/webapp/script/fancyzoom/images/zoom-spin-1.png
b461b000-b461d000 r--s 00000000 08:08 65801 /var/subsonic/jetty/1130/webapp/script/webfx/range.js
b461d000-b4620000 r--s 00000000 08:08 65751 /var/subsonic/jetty/1130/webapp/script/fancyzoom/FancyZoomHTML.js
b4620000-b4621000 r--s 00000000 08:08 65648 /var/subsonic/jetty/1130/webapp/icons/midnight/forward.png
b4621000-b4624000 r--s 00000000 08:08 65782 /var/subsonic/jetty/1130/webapp/script/swfobject.js
b4624000-b462a000 r--s 00000000 08:08 65750 /var/subsonic/jetty/1130/webapp/script/fancyzoom/FancyZoom.js
b462a000-b4634000 r--s 00000000 08:08 65749 /var/subsonic/jetty/1130/webapp/script/effects.js
b4634000-b4635000 r--s 00000000 08:08 65741 /var/subsonic/jetty/1130/webapp/icons/up.gif
b4635000-b4638000 ---p b4635000 00:00 0
b4638000-b4685000 rwxp b4638000 00:00 0
b4685000-b4686000 r--s 00000000 08:08 65779 /var/subsonic/jetty/1130/webapp/script/scriptaculous.js
b4686000-b4687000 r--s 00000000 08:08 65781 /var/subsonic/jetty/1130/webapp/script/smooth-scroll.js
b4687000-b46a7000 r--s 00000000 08:08 65778 /var/subsonic/jetty/1130/webapp/script/prototype.js
b46a7000-b46a8000 r--s 00000000 08:08 65818 /var/subsonic/jetty/1130/webapp/style/shadow.css
b46a8000-b46a9000 r--s 00000000 08:08 65635 /var/subsonic/jetty/1130/webapp/icons/donate_small.png
b46a9000-b46aa000 r--s 00000000 08:08 65736 /var/subsonic/jetty/1130/webapp/icons/search.png
b46aa000-b46ab000 r--s 00000000 08:08 65643 /var/subsonic/jetty/1130/webapp/icons/help.png
b46ab000-b46ac000 r--s 00000000 08:08 65689 /var/subsonic/jetty/1130/webapp/icons/more.png
b46ac000-b46ad000 r--s 00000000 08:08 65738 /var/subsonic/jetty/1130/webapp/icons/status.png
b46ad000-b46ae000 r--s 00000000 08:08 65737 /var/subsonic/jetty/1130/webapp/icons/settings.png
b46ae000-b46af000 r--s 00000000 08:08 65694 /var/subsonic/jetty/1130/webapp/icons/podcast_large.png
b46af000-b46b2000 ---p b46af000 00:00 0
b46b2000-b46ff000 rwxp b46b2000 00:00 0
b46ff000-b4702000 ---p b46ff000 00:00 0
b4702000-b474f000 rwxp b4702000 00:00 0
b474f000-b475e000 r-xp 00000000 08:01 55033 /lib/libresolv-2.8.90.so
b475e000-b475f000 r--p 0000e000 08:01 55033 /lib/libresolv-2.8.90.so
b475f000-b4760000 rw-p 0000f000 08:01 55033 /lib/libresolv-2.8.90.so
b4760000-b4762000 rw-p b4760000 00:00 0
b4762000-b4766000 r-xp 00000000 08:01 55023 /lib/libnss_dns-2.8.90.so
b4766000-b4767000 r--p 00003000 08:01 55023 /lib/libnss_dns-2.8.90.so
b4767000-b4768000 rw-p 00004000 08:01 55023 /lib/libnss_dns-2.8.90.so
b4768000-b4769000 r--s 00000000 08:08 65690 /var/subsonic/jetty/1130/webapp/icons/now_playing.png
b4769000-b476a000 r--s 00000000 08:08 65645 /var/subsonic/jetty/1130/webapp/icons/home.png
b476a000-b476c000 r--s 00000000 08:08 65740 /var/subsonic/jetty/1130/webapp/icons/subsonic_white.png
b476c000-b476d000 r--s 00000000 08:08 65780 /var/subsonic/jetty/1130/webapp/script/scripts.js
b476d000-b476f000 r--s 00000000 08:08 65808 /var/subsonic/jetty/1130/webapp/style/default.css
b476f000-b4770000 r--s 00000000 08:08 65814 /var/subsonic/jetty/1130/webapp/style/midnight.css
b4770000-b4776000 r--s 000fe000 08:01 98823 /usr/lib/jvm/java-6-openjdk/jre/lib/resources.jar
b4776000-b4779000 ---p b4776000 00:00 0
b4779000-b47c6000 rwxp b4779000 00:00 0
b47c6000-b47c9000 ---p b47c6000 00:00 0
b47c9000-b4816000 rwxp b47c9000 00:00 0
b4816000-b4819000 ---p b4816000 00:00 0
b4819000-b4866000 rwxp b4819000 00:00 0
b4866000-b4869000 ---p b4866000 00:00 0
b4869000-b48b6000 rwxp b4869000 00:00 0
b48b6000-b48b9000 ---p b48b6000 00:00 0
b48b9000-b4906000 rwxp b48b9000 00:00 0
b4906000-b4909000 ---p b4906000 00:00 0
b4909000-b4956000 rwxp b4909000 00:00 0
b4956000-b4959000 ---p b4956000 00:00 0
b4959000-b49a6000 rwxp b4959000 00:00 0
b49a6000-b49a9000 ---p b49a6000 00:00 0
b49a9000-b49f6000 rwxp b49a9000 00:00 0
b49f6000-b49f9000 ---p b49f6000 00:00 0
b49f9000-b4a46000 rwxp b49f9000 00:00 0
b4a46000-b4a49000 ---p b4a46000 00:00 0
b4a49000-b4a96000 rwxp b4a49000 00:00 0
b4a96000-b4a99000 ---p b4a96000 00:00 0
b4a99000-b4ae6000 rwxp b4a99000 00:00 0
b4ae6000-b4aea000 r--s 00076000 08:01 98803 /usr/lib/jvm/java-6-openjdk/jre/lib/ext/localedata.jar
b4aea000-b4bea000 rw-s 00000000 08:08 73738 /var/subsonic/db/subsonic.data
b4bea000-b4bed000 ---p b4bea000 00:00 0
b4bed000-b4c3a000 rwxp b4bed000 00:00 0
b4c3a000-b4c41000 r-xp 00000000 08:01 3228 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libnio.so
b4c41000-b4c42000 r--p 00006000 08:01 3228 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libnio.so
b4c42000-b4c43000 rw-p 00007000 08:01 3228 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libnio.so
b4c43000-b4c46000 ---p b4c43000 00:00 0
b4c46000-b4c93000 rwxp b4c46000 00:00 0
b4c93000-b4ca7000 r-xp 00000000 08:01 3227 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libnet.so
b4ca7000-b4ca8000 r--p 00013000 08:01 3227 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libnet.so
b4ca8000-b4ca9000 rw-p 00014000 08:01 3227 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libnet.so
b4ca9000-b4caa000 r--s 00002000 08:08 66233 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/basicplayer-3.0.jar
b4caa000-b4cac000 r--s 0000a000 08:08 66260 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/string-1.1.0.jar
b4cac000-b4cb1000 r--s 00040000 08:08 66239 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/commons-httpclient-3.0.1.jar
b4cb1000-b4cb3000 r--s 0000b000 08:08 66238 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/commons-fileupload-1.2.jar
b4cb3000-b4cc0000 r--s 000fa000 08:08 66250 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/jfreechart-1.0.0.jar
b4cc0000-b4cc7000 r--s 00071000 08:08 66261 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/subsonic-amazon-2006-03-08.jar
b4cc7000-b4cd4000 r--s 00079000 08:08 66229 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/acegi-security-1.0.5.jar
b4cd4000-b4cda000 r--s 0003f000 08:08 66234 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/cglib-2.1_3.jar
b4cda000-b4cdc000 r--s 0000e000 08:08 66255 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/oro-2.0.8.jar
b4cdc000-b4ce6000 r--s 00071000 08:08 66243 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/dwr-2.0.5.jar
b4ce6000-b4cee000 r--s 00096000 08:08 66246 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/hsqldb-1.8.0.7.jar
b4cee000-b4cf1000 r--s 0000f000 08:08 66237 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/commons-discovery-0.2.jar
b4cf1000-b4cf3000 r--s 00019000 08:08 66263 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/tritonus_share-0.3.6.jar
b4cf3000-b4cf8000 r--s 00034000 08:08 66244 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/ehcache-1.6.0-beta3.jar
b4cf8000-b4cfd000 r--s 00021000 08:08 66245 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/entagged-audioformats-0.15.jar
b4cfd000-b4d06000 r--s 0005a000 08:08 66258 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/spring-webmvc-2.5.6.jar
b4d06000-b4d08000 r--s 00004000 08:08 66252 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/jstl-1.1.2.jar
b4d08000-b4d09000 r--s 00006000 08:08 66231 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/asm-1.5.3.jar
b4d09000-b4d0b000 r--s 00006000 08:08 66247 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/jaxrpc-1.1.jar
b4d0b000-b4d48000 r--s 00294000 08:08 66257 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/spring-2.5.6.jar
b4d48000-b4d51000 r--s 00058000 08:08 66259 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/standard-1.1.2.jar
b4d51000-b4d53000 r--s 0000d000 08:08 66242 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/commons-logging-1.1.1.jar
b4d53000-b4d54000 r--s 00005000 08:08 66254 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/mp3spi-1.9.4.jar
b4d54000-b4d57000 r--s 0000d000 08:08 66262 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/subsonic-jme-player-3.8.jar
b4d57000-b4d5a000 r--s 00017000 08:08 66251 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/jlayer-1.0.1.jar
b4d5a000-b4d5d000 r--s 0001c000 08:08 66264 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/wsdl4j-1.5.1.jar
b4d5d000-b4d60000 r--s 00023000 08:08 66249 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/jdom-1.0.jar
b4d60000-b4d64000 r--s 0002f000 08:08 66241 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/commons-lang-2.1.jar
b4d64000-b4d78000 r--s 00174000 08:08 66232 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/axis-1.2.1.jar
b4d78000-b4d80000 r--s 0004f000 08:08 66253 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/log4j-1.2.9.jar
b4d80000-b4d86000 r--s 00043000 08:08 66248 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/jcommon-1.0.0.jar
b4d86000-b4d89000 r--s 00012000 08:08 66240 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/commons-io-1.3.1.jar
b4d89000-b4d96000 r--s 0007c000 08:08 66236 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/commons-collections-3.1.jar
b4d96000-b4da5000 r--s 000e6000 08:08 66230 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/ant-zip-1.6.2.jar
b4da5000-b4dab000 r--s 0002e000 08:08 66256 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/radeox-1.0-b2.jar
b4dab000-b4dbd000 r--s 00e7f000 08:08 65542 /var/subsonic/subsonic.war
b4dbd000-b4dc0000 ---p b4dbd000 00:00 0
b4dc0000-b4e0d000 rwxp b4dc0000 00:00 0
b4e0d000-b4eb5000 r--s 0099a000 08:08 65543 /var/subsonic/subsonic-booter-jar-with-dependencies.jar
b4eb5000-b4ebe000 r--s 00065000 08:01 67279 /usr/share/java/gnome-java-bridge.jar
b4ebe000-b4f66000 r--s 0099a000 08:08 65543 /var/subsonic/subsonic-booter-jar-with-dependencies.jar
b4f66000-b4f67000 ---p b4f66000 00:00 0
b4f67000-b4fe6000 rwxp b4f67000 00:00 0
b4fe6000-b4fe9000 ---p b4fe6000 00:00 0
b4fe9000-b5036000 rwxp b4fe9000 00:00 0
b5036000-b5039000 ---p b5036000 00:00 0
b5039000-b50b6000 rwxp b5039000 00:00 0
b50b6000-b50b9000 ---p b50b6000 00:00 0
b50b9000-b5106000 rwxp b50b9000 00:00 0
b5106000-b510d000 r--s 00000000 08:01 51757 /usr/lib/gconv/gconv-modules.cache
b510d000-b514c000 r--p 00000000 08:01 64829 /usr/lib/locale/sv_SE.utf8/LC_CTYPE
b514c000-b514f000 ---p b514c000 00:00 0
b514f000-b519c000 rwxp b514f000 00:00 0
b519c000-b519f000 ---p b519c000 00:00 0
b519f000-b51ec000 rwxp b519f000 00:00 0
b51ec000-b51ed000 ---p b51ec000 00:00 0
b51ed000-b526c000 rwxp b51ed000 00:00 0
b526c000-b529f000 rw-p b526c000 00:00 0
b529f000-b5433000 r--s 038b8000 08:01 99032 /usr/lib/jvm/java-6-openjdk/jre/lib/rt.jar
b5433000-b5442000 rwxp b5433000 00:00 0
b5442000-b545b000 rwxp b5442000 00:00 0
b545b000-b5460000 rwxp b545b000 00:00 0
b5460000-b546a000 rwxp b5460000 00:00 0
b546a000-b5470000 rwxp b546a000 00:00 0
b5470000-b547a000 rwxp b5470000 00:00 0
b547a000-b5482000 rwxp b547a000 00:00 0
b5482000-b549a000 rwxp b5482000 00:00 0
b549a000-b54b0000 rwxp b549a000 00:00 0
b54b0000-b5525000 rwxp b54b0000 00:00 0
b5525000-b57d5000 rwxp b5525000 00:00 0
b57d5000-b7525000 rwxp b57d5000 00:00 0
b7525000-b752c000 r-xp 00000000 08:01 3234 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libzip.so
b752c000-b752d000 r--p 00006000 08:01 3234 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libzip.so
b752d000-b752e000 rw-p 00007000 08:01 3234 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libzip.so
b752e000-b7552000 r-xp 00000000 08:01 3217 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libjava.so
b7552000-b7553000 r--p 00023000 08:01 3217 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libjava.so
b7553000-b7555000 rw-p 00024000 08:01 3217 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libjava.so
b7555000-b7561000 r-xp 00000000 08:01 3233 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libverify.so
b7561000-b7562000 ---p 0000c000 08:01 3233 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libverify.so
b7562000-b7563000 r--p 0000c000 08:01 3233 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libverify.so
b7563000-b7564000 rw-p 0000d000 08:01 3233 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libverify.so
b7564000-b756c000 rw-s 00000000 08:06 30722 /tmp/hsperfdata_root/9854
b756c000-b7575000 r-xp 00000000 08:01 55024 /lib/libnss_files-2.8.90.so
b7575000-b7576000 r--p 00008000 08:01 55024 /lib/libnss_files-2.8.90.so
b7576000-b7577000 rw-p 00009000 08:01 55024 /lib/libnss_files-2.8.90.so
b7577000-b757f000 r-xp 00000000 08:01 55027 /lib/libnss_nis-2.8.90.so
b757f000-b7580000 r--p 00007000 08:01 55027 /lib/libnss_nis-2.8.90.so
b7580000-b7581000 rw-p 00008000 08:01 55027 /lib/libnss_nis-2.8.90.so
b7581000-b7588000 r-xp 00000000 08:01 55021 /lib/libnss_compat-2.8.90.so
b7588000-b7589000 r--p 00006000 08:01 55021 /lib/libnss_compat-2.8.90.so
b7589000-b758a000 rw-p 00007000 08:01 55021 /lib/libnss_compat-2.8.90.so
b758a000-b759d000 r-xp 00000000 08:01 55019 /lib/libnsl-2.8.90.so
b759d000-b759e000 r--p 00012000 08:01 55019 /lib/libnsl-2.8.90.so
b759e000-b759f000 rw-p 00013000 08:01 55019 /lib/libnsl-2.8.90.so
b759f000-b75a1000 rw-p b759f000 00:00 0
b75a1000-b75a6000 rwxp b75a1000 00:00 0
b75a6000-b75ad000 r-xp 00000000 08:01 3236 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/native_threads/libhpi.so
b75ad000-b75ae000 r--p 00006000 08:01 3236 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/native_threads/libhpi.so
b75ae000-b75af000 rw-p 00007000 08:01 3236 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/native_threads/libhpi.so
b75af000-b75b6000 r-xp 00000000 08:01 55034 /lib/librt-2.8.90.so
b75b6000-b75b7000 r--p 00006000 08:01 55034 /lib/librt-2.8.90.so
b75b7000-b75b8000 rw-p 00007000 08:01 55034 /lib/librt-2.8.90.so
b75b8000-b75bb000 ---p b75b8000 00:00 0
b75bb000-b7608000 rwxp b75bb000 00:00 0
b7608000-b762c000 r-xp 00000000 08:01 55015 /lib/libm-2.8.90.so
b762c000-b762d000 r--p 00023000 08:01 55015 /lib/libm-2.8.90.so
b762d000-b762e000 rw-p 00024000 08:01 55015 /lib/libm-2.8.90.so
b762e000-b79ab000 r-xp 00000000 08:01 3201 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/client/libjvm.so
b79ab000-b79be000 r--p 0037d000 08:01 3201 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/client/libjvm.so
b79be000-b79ca000 rw-p 00390000 08:01 3201 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/client/libjvm.so
b79ca000-b7dea000 rw-p b79ca000 00:00 0
b7dea000-b7f27000 r-xp 00000000 08:01 54962 /lib/libc-2.8.90.so
b7f27000-b7f29000 r--p 0013d000 08:01 54962 /lib/libc-2.8.90.so
b7f29000-b7f2a000 rw-p 0013f000 08:01 54962 /lib/libc-2.8.90.so
b7f2a000-b7f2d000 rw-p b7f2a000 00:00 0
b7f2d000-b7f2f000 r-xp 00000000 08:01 55014 /lib/libdl-2.8.90.so
b7f2f000-b7f30000 r--p 00001000 08:01 55014 /lib/libdl-2.8.90.so
b7f30000-b7f31000 rw-p 00002000 08:01 55014 /lib/libdl-2.8.90.so
b7f31000-b7f35000 r-xp 00000000 08:01 3206 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/jli/libjli.so
b7f35000-b7f36000 r--p 00003000 08:01 3206 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/jli/libjli.so
b7f36000-b7f37000 rw-p 00004000 08:01 3206 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/jli/libjli.so
b7f37000-b7f4b000 r-xp 00000000 08:01 55031 /lib/libpthread-2.8.90.so
b7f4b000-b7f4c000 r--p 00013000 08:01 55031 /lib/libpthread-2.8.90.so
b7f4c000-b7f4d000 rw-p 00014000 08:01 55031 /lib/libpthread-2.8.90.so
b7f4d000-b7f4f000 rw-p b7f4d000 00:00 0
b7f4f000-b7f63000 r-xp 00000000 08:01 48056 /usr/lib/libz.so.1.2.3.3
b7f63000-b7f65000 rw-p 00013000 08:01 48056 /usr/lib/libz.so.1.2.3.3
b7f65000-b7f66000 r--s 00000000 08:08 65744 /var/subsonic/jetty/1130/webapp/index.html
b7f66000-b7f68000 r--s 00006000 08:08 66235 /var/subsonic/jetty/1130/webapp/WEB-INF/lib/commons-codec-1.2.jar
b7f68000-b7f69000 rwxp b7f68000 00:00 0
b7f69000-b7f6a000 r--p b7f69000 00:00 0
b7f6a000-b7f6c000 rw-p b7f6a000 00:00 0
b7f6c000-b7f86000 r-xp 00000000 08:01 54959 /lib/ld-2.8.90.so
b7f86000-b7f87000 r-xp b7f86000 00:00 0 [vdso]
b7f87000-b7f88000 r--p 0001a000 08:01 54959 /lib/ld-2.8.90.so
b7f88000-b7f89000 rw-p 0001b000 08:01 54959 /lib/ld-2.8.90.so
bfb54000-bfb89000 rwxp bffcb000 00:00 0 [stack]
VM Arguments:
jvm_args: -Xmx32m -Dsubsonic.home=/var/subsonic -Dsubsonic.host=0.0.0.0 -Dsubsonic.port=8081 -Dsubsonic.contextPath=/subsonic -Dsubsonic.defaultMusicFolder=/mnt/media/Music -Dsubsonic.defaultPodcastFolder=/mnt/media/Podcast -Dsubsonic.defaultPlaylistFolder=/mnt/media/playlists
java_command: subsonic-booter-jar-with-dependencies.jar
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/X11R6/bin
USERNAME=root
LD_LIBRARY_PATH=/usr/lib/jvm/java-6-openjdk/jre/lib/i386/client:/usr/lib/jvm/java-6-openjdk/jre/lib/i386:/usr/lib/jvm/java-6-openjdk/jre/../lib/i386
SHELL=/bin/bash
Signal Handlers:
SIGSEGV: [libjvm.so+0x3290e0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGBUS: [libjvm.so+0x3290e0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGFPE: [libjvm.so+0x2701c0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGPIPE: [libjvm.so+0x2701c0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGXFSZ: [libjvm.so+0x2701c0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGILL: [libjvm.so+0x2701c0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR2: [libjvm.so+0x26fb70], sa_mask[0]=0x00000000, sa_flags=0x10000004
SIGHUP: [libjvm.so+0x271d00], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGINT: SIG_IGN, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGTERM: [libjvm.so+0x271d00], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGQUIT: [libjvm.so+0x271d00], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
--------------- S Y S T E M ---------------
OS:Ubuntu 8.10 (intrepid)
uname:Linux 2.6.27-11-server #1 SMP Thu Jan 29 20:19:41 UTC 2009 i686
libc:glibc 2.8.90 NPTL 2.8.90
rlimit: STACK 8192k, CORE 0k, NPROC infinity, NOFILE 1024, AS infinity
load average:0.35 0.20 0.08
CPU:total 1 (1 cores per cpu, 1 threads per core) family 6 model 8 stepping 1, cmov, cx8, fxsr, mmx, sse
Memory: 4k page, physical 514152k(223160k free), swap 899632k(899632k free)
vm_info: OpenJDK Client VM (1.6.0_0-b12) for linux-x86 JRE (1.6.0_0-b12), built on Nov 10 2009 01:34:40 by "buildd" with gcc 4.3.2
time: Thu Jan 7 14:12:31 2010
elapsed time: 130 seconds
migu
