Subsonic + Debian Squeeze
Postby Raphael » Mon Jan 11, 2010 9:49 pm
I have little problem with Subsonic. When subsonic.sh was launched, i had a blank page in my browser. I have tried to scan open ports and the 80 was closed ! I have follow these steps :
1 - DL Subsonic :
wget http://prdownloads.sourceforge.net/subsonic/subsonic-3.8-standalone.tar.gz
2 - Install Java :
apt-get install sun-java6-jre
3 - Create Subsonic directory :
mkdir -p /var/subsonic/standalone
4 - Untar archive in desired folder :
tar -C /var/subsonic/standalone -zvxf subsonic-3.8-standalone.tar.gz
5 - Change listen port 8080 to 80 :
nano /var/subsonic/standalone/subsonic.sh
6 - Launch sh script :
This text appear :
Started Subsonic [PID 4250, /var/subsonic/subsonic_sh.log]
But when i use my browser to open Subsonic at : http://192.168.1.1/, i have no response.
It's very strange and subsonic run like a charm :
4250  1.0  4.5 415136 94460 pts/0    Sl   22:25   0:11 java -Xmx64m -Dsubsonic.home=/var/subsonic -Dsubsonic.host=0.0.0.0 -Dsubsonic.port=80 -Dsubsonic.contextPath=/ -Dsubsonic.defaultMusicFolder=/var/music -Dsubsonic.defaultPodcastFolder=/var/music/Podcast
Do you have any ideas ? I'm feed it up with it :(
PS : I have tried with port 8080, I have the same problem.
Freenas Server, Subsonic & Hallanzbd+ / Pictures of my NAS / :D
_________________
349 artists
858 albums
10 964 songs
56,43 GB (~ 876 hours)
Raphael
Postby p2ranger » Tue Jan 12, 2010 3:46 pm
I'm guessing you have subsonic running on the same computer you are trying to access it from. Have you tried just typing localhost into your browser?
Subsonic 5.3
Ubuntu 14.04
p2ranger
Postby Raphael » Tue Jan 12, 2010 7:30 pm
Subsonic runs on my server and i just want to access it with server ip's.
Server IP : 192.168.1.1
My computer : 192.168.1.103
:idea:
_________________
349 artists
858 albums
10 964 songs
Raphael
Postby p2ranger » Tue Jan 12, 2010 8:00 pm
Just making sure you have added the port number to the URL you are putting in your browser as well as a subdirectory if it is installed in one:
http://192.168.1.1:8080/subsonic
Although you seem to have yours running on port 80, then you shouldn't have to add a port number as 80 is default.
Subsonic 5.3
Ubuntu 14.04
p2ranger
Postby Raphael » Tue Jan 12, 2010 8:25 pm
Subsonic.sh var :
SUBSONIC_HOME=/var/subsonic
SUBSONIC_HOST=0.0.0.0
SUBSONIC_PORT=80
SUBSONIC_CONTEXT_PATH=/
SUBSONIC_MAX_MEMORY=64
SUBSONIC_PIDFILE=
SUBSONIC_DEFAULT_MUSIC_FOLDER=/var/music
SUBSONIC_DEFAULT_PODCAST_FOLDER=/var/music/Podcast
SUBSONIC_DEFAULT_PLAYLIST_FOLDER=/var/playlists
I just want to launch Subsonic on port 80 (remember : whatever chosen port, i have the same problem :idea: )
I launch :
and get :
Started Subsonic [PID 2292, /var/subsonic/subsonic_sh.log]
Now, ps -aux | grep java shows that :
root      2259  1.7  2.8 228916 58328 pts/0    Sl   21:11   0:11 java -Xmx64m -Dsubsonic.home=/var/subsonic -Dsubsonic.host=0.0.0.0 -Dsubsonic.port=80 -Dsubsonic.contextPath=/ -Dsubsonic.defaultMusicFolder=/var/music -Dsubsonic.defaultPodcastFolder=/var/music/Podcast -Dsubsonic.defaultPlaylistFolder=/var/playlists -jar subsonic-booter-jar-with-dependencies.jar
Now, i go to my server ip's in Firefox and I get "Connexion failed"
PS :
Subsonic log :
4 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@750159: display name [org.springframework.context.support.ClassPathXmlApplicationContext@750159]; st$
147 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
891 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@750159]: org.springframework.beans.factory.support.DefaultListableBeanFa$
916 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@156b6b9: defining beans [service,org.springframework.remoting.rmi.RmiServi$
971 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
Using WAR file: /var/subsonic/standalone/subsonic.war
Extracting webapp to /var/subsonic/jetty/1130
1043 [main] INFO org.mortbay.log - jetty-6.1.x
33077 [main] INFO / - Initializing Spring root WebApplicationContext
33078 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization started
33130 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@1dc0e7a: display name [Root WebApplicationContext]; startup date [Tue Jan 12 21:37:03 CET 2010]; root$
33211 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-service.xml]
33591 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-security.xml]
33704 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-cache.xml]
33824 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@1dc0e7a]: org.springframework.beans.factory.support.DefaultListableBeanFac$
34014 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@17b0998: defining beans [playerDao,internetRadioDao,musicFileInfoDao,mus$
34190 [main] INFO org.springframework.jdbc.datasource.DriverManagerDataSource - Loaded JDBC driver: org.hsqldb.jdbcDriver
35298 [main] INFO org.springframework.cache.ehcache.EhCacheManagerFactoryBean - Initializing EHCache CacheManager
12 janv. 2010 21:37:06 net.sf.ehcache.CacheManager addShutdownHookIfRequired
INFO: The CacheManager shutdown hook is enabled because net.sf.ehcache.enableShutdownHook is set to true.
12 janv. 2010 21:37:06 net.sf.ehcache.Cache initialise
ATTENTION: Cache: chatCache has a maxElementsInMemory of 0. It is strongly recommended to have a maximumSize of at least 1. Performance is halved by not using a MemoryStore.
ATTENTION: Cache: musicFolderCache has a maxElementsInMemory of 0. It is strongly recommended to have a maximumSize of at least 1. Performance is halved by not using a MemoryStore.
35776 [main] INFO org.acegisecurity.intercept.AbstractSecurityInterceptor - Validated configuration attributes
35791 [main] INFO org.acegisecurity.intercept.method.MethodDefinitionMap - Adding secure method [public net.sourceforge.subsonic.ajax.UploadInfo net.sourceforge.subsonic.ajax.TransferService.getUploadInfo()] with attributes [[ROLE_UPLOAD]]
35792 [main] INFO org.acegisecurity.intercept.method.MethodDefinitionMap - Adding secure method [public java.lang.String net.sourceforge.subsonic.ajax.TagService.setTags(java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.la$
35792 [main] INFO org.acegisecurity.intercept.AbstractSecurityInterceptor - Validated configuration attributes
35846 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization completed in 2768 ms
35928 [main] INFO / - Initializing Spring FrameworkServlet 'subsonic'
35928 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization started
35929 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@1e1ec86: display name [WebApplicationContext for namespace 'subsonic-servlet']; startup date [Tue Jan$
35930 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/subsonic-servlet.xml]
36283 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@1e1ec86]: org.springframework.beans.factory.support.DefaultListableBeanFac$
36498 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1706eb7: defining beans [leftController,rightController,statusController$
37608 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization completed in 1680 ms
37656 [main] INFO org.mortbay.log - Started SelectChannelConnector@0.0.0.0:8080
Subsonic running on http://localhost:8080/
37736 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
37757 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
_________________
349 artists
858 albums
10 964 songs
Raphael
Postby PRAEst76 » Sat Mar 06, 2010 5:20 pm
I'm having this same issue. Runs fine on my Ubuntu Karmic Desktop machine, but not on the my Debian box I want to be able to run it on.
PRAEst76
