issue with Subsonic play back
Postby LesserPhil » Tue Jan 12, 2010 3:01 pm
Hello all - I have subsonic up and running with tomcat / jakarta / IIS
everything is working fine however when I play songs longer then 5 minutes the play back stops after like 3 minutes. also subsonic does not seem to play my wma files.
any ideas?
Phil
LesserPhil
anyone?
Postby LesserPhil » Mon Jan 18, 2010 4:07 pm
I could really use some help here -
Subsonic is working, however I cannot play songs they randomly stop 2/3 the way through.
Subsonic will not play .WMA files
I have reinstalled multiple times. Enabled all the default transcoders and still no luck, the only thing have not tried is increasing the RAM on the tomcat server.
Please any help / ideas would be helpful.
LesserPhil
update -
Postby LesserPhil » Mon Jan 18, 2010 4:56 pm
I removed all the transcoders from c:\subsonic\transcode and subsonic was able to play my .mp3's
any idea on how to get the transcoders installed correctly,
I downloaded them directly from the subsonic site and put them in c:\subsonic\transcode
then followed these directions to troubleshot:
Is the transcoder's enabled checkbox turned on (in Settings > Transcoders)?
Is the transcoder activated for your player (in Settings > Players)?
Is the proper file extension added to the music mask (in Settings > General)?
the goal is to enable the transcoding feature in lame to modify the bandwidth being used.
does anyone have any ideas on how to fix this?
LesserPhil
Update -
Postby LesserPhil » Mon Jan 18, 2010 6:16 pm
after installing flashplayer update and re-adding the trancode folder to c:\subsonic and re-enabling the transcode option in subsonic settings - I was able to play .mp3's and .wma's with out fail!
LesserPhil
