Home Stereo Server configuration
Postby plaiming » Sat Jan 16, 2010 5:33 pm
I am trying to use Subsonic as home music server through a laptop connected to my home stereo. I am trying to setup a single user account, "music", that operates in jukebox mode that anyone in the household can use to login and control the music (ie stop/start music, add to playlist)
The main problem I am encountering is that when I try to login as "music" from 2 different pcs, the second pc to login does not operate in jukebox mode - subsonice automatically assigns a stream player to that user.
Is there a way to prevent this from happening? I just want a simple system where people can login from multiple pcs and control the account in jukebox mode.
-paul
plaiming
Postby tommyperkins » Mon Jan 25, 2010 10:00 pm
I had to delete all current players then create one instance on the server in Jukebox mode. When anyone else logs in just try and use that (should only be one in the drop-down box).
tommyperkins
