Symlink Directory Structure for e.g. Browse by Genre
Postby dacc » Mon Jan 25, 2010 11:55 pm
Hello Board,
I'm new to Subsonic, and really liking it so far. One stumbling block for me is not being able to browse by genre, etc. as is a common functionality with other music library managers.
A thought I had was to write some scripts that would build out a directory tree of symlinks for this purpose. e.g. At the toplevel have a "Genres" tree that contains folder for different genres, and then symlinks within those to actual albums, etc.
How would this interact with the search indexing? Lots of redundant work and duplication?
- Daniel
dacc
Postby dacc » Sat Feb 06, 2010 11:03 pm
Hey, so, any ideas on this? Thanks.
dacc
Postby flacflac » Sun Feb 07, 2010 5:18 pm
I have never tested how subsonic responds to symbolic links, but why don't you give it a shot and tell us? What OS are you running? An alternative way to do this would probably be using a FUSE file system on linux that basically mirrors directories based on tags, although that might end up being a tad more work to implement... . :)
ff
flacflac
Postby markstuartwalker » Wed Jun 16, 2010 3:58 pm
You might like to see my implementation of symbolic links from MediaMonkey.
http://www.mediamonkey.com/forum/viewto ... =2&t=49774
This takes MM playlists and produces a linux script that creates symbolic links to represetn the playlists as folder/file structures.
markstuartwalker
