What version of Flash does the player require?
Postby hdave » Tue Jan 26, 2010 2:49 am
I have a brand new Wii that I used to stream music on using Jinzora. Now that I have switched to Subsonic, it doesn't work. I believe the Opera browser in the Wii supports up to version 8 of flash. Youtube and other sites play audio/video just fine.
Any reason why Subsonic wouldn't play? I am guessing it is the flash version of the player required...
hdave
Postby Ravefiend » Fri Jan 29, 2010 2:33 pm
Like you mentioned, the Wii truly comes with a crippled browser without proper Flash support. I tried it too the other day and came to same conclusion as you: it won't work. 8)
On the technical aspects of Subsonic I can confirm that it required Flash 9.0.0 at the minimum. Now the fun part is that is DOES work on a PlayStation 3 as that does support Flash 9. Tested it before and confirmed to be working properly. :wink:
Ravefiend
Postby hdave » Sat Jan 30, 2010 4:53 am
Check out this link.
http://my.opera.com/haavard/blog/2009/09/01/free-internet-channel-with-updated-flash
It seems to indicate its at v9 -- but no actionscript support.
I did download the update referred to and can play youtube, etc. Does the Subsonic player require actionscript?
hdave
