Tomcat 6 and SSL - JW Player not shown in IE
Postby Ravefiend » Fri Jan 29, 2010 2:23 pm
I'm fiddling around with Tomcat 6 on which I enable SSL / HTTPS using a self signed certificate. Things are working smooth using Firefox yet Internet Explorer doesn't want to load the JW Player. Right mouse click on the Flash object shows the message:
Movie not loaded...
There seems to be a big fuzz about all that as per these references:
http://kb2.adobe.com/cps/000/fdc7b5c.html
http://blog.phy5ics.com/2007/08/14/flas ... -solution/
http://www.blog.lessrain.com/flash-nast ... -explorer/
http://faindu.wordpress.com/2008/04/18/ ... eam-error/
I tried adding the following after the include.jsp:
<meta http-equiv="Cache-Control" content="cache, must-revalidate">
<meta http-equiv="Pragma" content="public">
It does show up nicely in the source (<head>of playlist) of the page yet IE still refuses to launch the JW Player. I'm really curious to know what setup set I could have missed here. :)
Ravefiend
Re: Tomcat 6 and SSL - JW Player not shown in IE
Postby flacflac » Sat Jan 30, 2010 1:55 am
Hi Ravefiend,
Ravefiend wrote:I'm fiddling around with Tomcat 6 on which I enable SSL / HTTPS using a self signed certificate. Things are working smooth using Firefox yet Internet Explorer doesn't want to load the JW Player.
Alright, I would say it's working, your IE seems a bit off.
Okay, I did not check them all, but they are a bit oldish and referring to IE7, which you really should not be using anymore.
I am using Tomcat 6 via SSL and things work fine in IE and Opera. I would suggest you
- install the latest IE
- do a complete swipe of all cookies/temporary internet files and whatnot that might be on your harddrive, especially if already using the latest IE
- try to install the new FLASH beta if nothing works, it might help
- make sure your certificate is accepted in your IE - the latest version doesn't even let you access the page unless you explicitly click on a red colored link, but perhaps adding your own certificate into your trusted list makes a difference?
- also try to lower your security prefs for a minute to see if that's a possible cause
If you want me to test it from a different machine just send me a PM.
ff :shock:
flacflac
Postby Ravefiend » Sun Jan 31, 2010 8:16 am
Thanks for commenting upon this flacflac! :D .. I'm actually using IE 8 on Windows 7 Ultimate and yes, it all has to do with the certificate so it seems.
I've now completed the steps outlined on this page:
http://stackoverflow.com/questions/6816 ... ertificate
Now I'm up against another Certificate Error described as Mismatched Address. So, back to the drawing board with this to see if I need to create another one. Darn IE.... :)
Ravefiend
Postby bushman4 » Mon Aug 22, 2011 6:38 pm
I found the solution to this issue and thought I'd share...
(BTW, I think that this can be done at the application level if Sindre wants to, but I chose to do it at the server level to cover all applications)
If you open your global context.xml file (in the conf directory in Windows, not sure on *nix) and add the following line:
<Valve className="org.apache.catalina.authenticator.BasicAuthenticator"  disableProxyCaching="false" />
between the <CONTEXT> and </CONTEXT> tags, and restart Tomcat, the JWPlayer will load correctly (regardless of certificate errors).
I also figured out how to make a self-signed certificate that includes ALL of the possible addresses (including internal and external IP addresses) so that IE and Chrome will stop complaining that the addresses don't match. That will be a different post.
HTH someone...
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby ultrasonic » Thu Sep 15, 2011 12:46 am
Chrome is the solution, I'm tellin' ya. If you change your browser and run a function all should be back to normal. Have you guys ever tried this method before? I have been using in for the past six months whenever I run in to trouble...
ultrasonic
Postby bushman4 » Thu Sep 15, 2011 12:01 pm
Sure... try explaining a brand new browser interface to your 60 year old mother just so she can log onto your subsonic server...
But seriously, that is the beauty of so called "cloud" applications like this... it shouldn't matter WHAT browser you use. It should just work.
And yes, MY primary browser is Chrome. But it shouldn't matter in the grand scheme.
My $.02,
Glenn
Glenn Sullivan
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Users browsing this forum: Google [Bot] and 22 guests
