transcoding issues
transcoding issues
Postby dcorwin822 » Sun Jan 31, 2010 5:59 am
Hi everyone. I'm trying to get ffmpeg to work on my ubuntu 9.10 system. I built ffmpeg from the SVN and I am trying to get the program to transcode using this following suggestion
http://forum.subsonic.org/forum/viewtop ... e+lossless
I only have M4A (apple lossless) and MP3s in my music directory. So this is pretty much all i need it for and i can't seem to get it to work. Mp3s work fine.
I chmod 0755 the ffmpeg and the script in my transcode folder at /var/subsonic/transcode
dcorwin822
Postby colli419 » Mon Feb 01, 2010 8:06 pm
dcorwin822:
I am using a similar operating environment but went about setting it up a bit differently. I also have a lot of m4a files on my box because some of my users are mac-infested... :) Either way, the best way that I found to do this was faad. You can run:
sudo apt-get install faad
then copy the executable from your /usr/ to your transcode directory then run:
sudo chown -R yourname:yourgroup transcode
sudo chmod -R 775 transcode
Then use these settings in your transcoding tab:
Step 1) "faad -o - %s"
Step 2) "lame -h -b %b - -"
colli419
