files on network share
Postby teaconsult » Fri Feb 05, 2010 6:59 am
I have my music files located on a network share and i was wondering how i would set that up in the settings
I tried
\\10.80.0.2\Elements (I)\My Music\iTunes\iTunes Music\Music
and even tried to map a network drive but that also didnt work.
Z:\My Music\iTunes\iTunes Music\Music
I have over 300 gig of music and videos and i dont want to put it on the server.
I can run it to a local folder and it works but I need it to go to the share for all files.
teaconsult
Postby ootuoyetahi » Sat Mar 27, 2010 2:19 pm
Did you ever figure this out? I have a similar situation.
ootuoyetahi
Postby teaconsult » Sun Mar 28, 2010 3:12 am
Sorry No, no one would ever reply to me on this.
teaconsult
Postby djshaggy » Mon Mar 29, 2010 4:24 am
I have the same problem. Would like to know a solution if anyone has a clue.
djshaggy
Postby Caleb » Mon Mar 29, 2010 10:16 am
Yes, I don't understand why this is not a sticky or at least mentioned somewhere!
I fixed this by changing the user of the Subsonic service in the Services Management.
Caleb
Postby ootuoyetahi » Mon Mar 29, 2010 12:37 pm
That wont work for me as i am trying to run it on Ubuntu Server 9.10. The support here is horrible though.
ootuoyetahi
Postby Aethies » Mon Mar 29, 2010 2:32 pm
ootuoyetahi wrote:That wont work for me as i am trying to run it on Ubuntu Server 9.10. The support here is horrible though.
What is the problem? I run Subsonic between 2 Ubuntu servers with no issues. If you want, I can post how my servers are set up. I just forget to check back from time to time here.
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
2636.09 GB (10,769 hours)
Aethies
Postby ootuoyetahi » Mon Mar 29, 2010 9:12 pm
You can see the thread I created about this here at http://forum.subsonic.org/forum/viewtopic.php?t=2970
I can quickly explain it here too.
I am running ubuntu 9.10 server in a virtual environment. This server's sole purpose is to run Subsonic. I installed Java and the *.deb found here http://prdownloads.sourceforge.net/subs ... ic-3.9.deb. So far so good. I can connect to the web interface fine. The issue I have is that I cannot for the life of me get this to recgonize my samba shares. I know the shares are good as I can connect to them from my windows 7 box (and various other boxes) with no problem. I have tried every possible syntax I can think of, it just doesnt work.
I have tried:
\\IPADDRESS\share\folder
smb:/IPADDRESS/path/to/folder
smb:/user:password@IPADDRESS/path/to/folder
Nothing works, and I am out of ideas. Can you shed some light on this?
ootuoyetahi
Postby Poffa » Mon Mar 29, 2010 9:44 pm
Have you tried mounting the drives in /etc/fstab and then adding the mounted path to subsonic?
I have this setup:
# Mount music
//192.168.0.134/Music /home/username/Music   cifs   auto,credentials=/root/.credentials,uid=1000,umask=000,user   0 0
Then add /home/username/Music to Subsonic.
Poffa
Postby ootuoyetahi » Mon Mar 29, 2010 9:53 pm
They are mounted in the fstab - I forgot to mention it is part of a software raid 5. Here is the fstab line:
/dev/md0 /glftpd/site/ auto defaults 0 3
ootuoyetahi
Postby ootuoyetahi » Tue Mar 30, 2010 12:45 am
Oh, the fstab on the box that is running subsonic? I will try that.
ootuoyetahi
Postby ootuoyetahi » Tue Mar 30, 2010 2:48 pm
So I finally got it to index my music. Now i want to enable SSL. Can anyone help with that?
ootuoyetahi
Postby Aethies » Tue Mar 30, 2010 3:39 pm
ootuoyetahi wrote:So I finally got it to index my music. Now i want to enable SSL. Can anyone help with that?
Good luck! I still haven't got it to work in Tomcat 6.. I get it to open the listening port, but unable to connect. Firewall is even forwarding to the correct port.
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
Aethies
Postby ootuoyetahi » Wed Mar 31, 2010 7:53 pm
I see that. And that kind of goes back to my initial comment of the support is horrible. The documentation is horrible as well. Do i need Tomcat or can I use Apache. I wish there were an official doc i could refer too...
ootuoyetahi
Postby Pathduck » Wed Mar 31, 2010 8:48 pm
ootuoyetahi wrote:I see that. And that kind of goes back to my initial comment of the support is horrible. The documentation is horrible as well. Do i need Tomcat or can I use Apache. I wish there were an official doc i could refer too...
That's not really fair to say the support is horrible - remember this is a *Free* product made by a single person. Of course he cannot answer every single question, and has to rely on users helping users.
As to your problems, how to mount a fileshare is not really what the Subsonic documentation should take care of. Neither is setting up SSL as that includes stuff like SSL keyfiles and getting your key signed by a CA.
That should be taken of in your app server (Tomcat etc) documentation, or if you are running a standalone, maybe in the Jetty documentation.
http://docs.codehaus.org/display/JETTY/ ... figure+SSL
Have you donated by the way? :lol:
Pathduck
