Set up a Schoutcast Radio Stream
Postby karaya1 » Fri Feb 05, 2010 8:25 pm
Is it possible to serve a Shoutcast-Radio-Stream with Subsonic.
I would have tested it, but the Problem is, that in Subsonic i see no Possibility to set the Password for the Shoutcast-Server needed.
TIA
karaya1
Postby trev » Tue Jul 20, 2010 1:02 am
Kind of an old post but I would like to do the same thing. Any help would be great. Thanks
trev
Postby j3tblk » Wed Sep 15, 2010 8:35 am
bump. We need documentation\instructions!!! 4 Shoutcast configs!
Hey OP if you spell things correctly your post might get found via searches.
j3tblk
Postby Kirk » Sun Sep 19, 2010 7:07 pm
Subsonic != Shoutcast.
This is not an extremely uncommon question. Nothing is stopping you from running a Shoutcast server on the same system you're using to host Subsonic, for that matter there's nothing stopping you from using the same music collection. But Subsonic doesn't do Shoutcast.
Here's a tutorial that you might find useful:
http://forums.winamp.com/showthread.php?t=35635
Cheers,
Kirk
Kirk
