How can I change the folder location C:\subsonic?
Postby librainian » Sun Feb 07, 2010 7:25 pm
I'd like to move this to another partition and can't find any mention of where this directory value is stored. I tried searching the registry and the config files without success. Thanks!
librainian
And the answer is....
Postby librainian » Sun Feb 14, 2010 9:04 am
Sindre answered this of course...
1. stop subsonic with the control panel.
2. copy the entire folder c:\subsonic to your new location and rename the original
3. open up program files/subsonic/subsonic-service.exe.vmoptions
4. add the line -Dsubsonic.home=x:/<your new subsonic directory location>
5. restart Subsonic.
6. subsonic should use the newly copied folder instead.
7. If you messed up, subsonic will create a new folder c:\subsonic if that doesn't appear then your good to go. delete the old folder
librainian
