New Bug in 3.9 and a old Bug
Postby deejay2302 » Thu Feb 11, 2010 7:30 am
Bug 1
I have installed the 3.9 Version of Subsonic and it works correctly. I test the new Feature Network/Access your server over the Internet using an easy-to-remember address
It Works fine but i become a failure message.
Status: xxxx.subsonic.org is registered, but could not connect to it. (ConnectTimeoutException)
wth? I test it and it works!! no failure^^ Failure from what?
Bug 2 (old)
I've set the subsonic he informed me about new beta versions. It appears to me, but nothing that a new beta version is released.
21.681 Artists
58.141 Albums
674.091 Songs
5072,14 GB (~ 49.341 Hours)
deejay2302
Postby sindre_mehus » Thu Feb 11, 2010 11:53 am
Have you tried to access xxxx.subsonic.org from outside your LAN? It might work internally on your local network, but not necessarily from outside.
Postby deejay2302 » Fri Feb 12, 2010 12:59 pm
No. In LAN for testing.^^ Is this the failure?
21.681 Artists
58.141 Albums
674.091 Songs
deejay2302
Postby sindre_mehus » Fri Feb 12, 2010 1:22 pm
Are you using port 8080?
I recently discovered that my hosting provider (GoDaddy) blocks outbound connections (from subsonic.org) to port 8080. Thus, the "Test" link in Network > Settings doesn't work if you are using port 8080.
However, the address redirection still works, as you pointed out.
