Help Needed! Subsonic Wont Work From An External Connection
Postby Migz93 » Sun Feb 14, 2010 2:20 am
Im hoping you can help me as i cant get people who arent on my network to connect to Subsonic.
Heres my setup.
Windows 7
Windows Firewall
Subsonic is added to the program exception list. (I've also tried turning my firewall completely off incase it still wasnt letting the connection through but it still didnt work.
Avast
I've tried turning Avast Antivirus off completely incase it has a firewall in it.
Subsonic
Port 8080
Memory Limit 400mb.
Belkin Router/Modem.
Port forwarding settings
Inbound port 8080, private port 8080.
Type UCP/TDP
Pointing towards the correct internal IP address.
Port Checker from www.portforwarding.com says the port is open.
When i try connecting to Subsonic with
http://192.168.2.8:8080 = Works Fine.
http://localhost:8080 = Works Fine.
But
http://XX.XXX.XXX.XXX = Comes up with the configuration page for my router/modem
http://XX.XXX.XXX.XXX:8080 = Comes up with a "Oops! This link appears to be broken." page on google.
As far as i can tell i've not done anything wrong so what could it be that's messing it up?
If you need anymore info then i'll be glad to give it.
Migz93
Postby Francolino » Sun Feb 14, 2010 11:55 pm
Some Router are unable to route the Access via the Internet to themself. Please try the access from another computer , eg an friend of you.
Francolino
Postby Migz93 » Tue Feb 16, 2010 3:15 am
Thank you, got a friend to check it and it worked :)
Migz93
